Question about Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Sony bravia kdl 26S2000 turns itself off and then on after a few seconds
Sony bravia is attached to a cable box and turns itself on and off. when unplugged from cable box for a few minutes it works ok for a couple of days and then goes back to off and on problem
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
  • 1779 Answers
SOURCE: My LCD Sony HD tv turns off after few seconds.
You need the Inverter Board.
Posted on Sep 14, 2009
SOURCE: KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
  • 6 Answers
SOURCE: Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Posted on Dec 26, 2009
Turn off teletext 888
Click here to download the user manual to this set, and refer it.
Jun 09, 2012 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Apple tv and Sony Bravia 26S2030
HDMI contains both video, color and audio all in one cable----audio connection with it is not without issues.
May 14, 2012 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Which button on the remote control is for switching from TV to AV (VCR)?
The TV/Video button on the original remote for the KDL-26S2000 should let you cycle through the inputs on the TV. This button is at the upper left of the remote. (However, if you have set the system to Skip inputs, you may need to remove the skip option.)
There is also a TV/Video button on the front of the TV. It's the second button from the left on the panel (it's just to the right of the menu button).
To reset the input list, press Menu and navigate to Settings. Select the Setup sub-menu and then select the Label Video Inputs. Give the input any label other than skip.
Some TVs work best if the TV is turned on and set to that input source before you turn on the source device.
For additional information and pictures of the menus, see the manual. It is available from Sony support: http://esupport.sony.com/US/perl/model-home.pl?mdl=KDL26S2000&template_id=1&region_id=1&tab=manuals#/manualsTab (see the Manuals, Specs and Warranty tab). The direct link to the manual is http://www.docs.sony.com/release/KDL40S2000.pdf .
I hope this helps.
Dec 31, 2011 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Sony Bravia has sound but no picture
hi have you check the sleep timer on the tv cause it might be on and you need to turn it off
Jan 12, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
Oct 06, 2008 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Sony BRAVIA KDL-26S2000 26 in. LCD HDTV Logo
57 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
