Question about Garden
No fuel to plug - Garden
    New Friend:
  • 30 Answers
Check to see that all fuel lines are clear, if they are, check the carb to make sure it's not pluged up.
Posted on Jan 01, 2013
Like to locate fuel switch engine turns not getting gas
Oh, Hi David it's either fuel or spark... To check for spark just pull a spark plug lead off a spark plug and plug the spark plug lead onto a SPARE spark plug, Now earth it to the CLEAN motor or body (make sure the spark plug is touching metal) Turn the motor over using the ignition, If the spark plug doesn't spark then it could be coil... If it's sparking then you have a fuel problem, The fuel pump is usually in the fuel tank BUT I have no idea about the year, make or model number your car is....CHEERS..
Mar 27, 2016 | Cars & Trucks
Why dont my car pick up
You mean it has no power on acceleration ? plugged catalytic converter ! , maybe plugged fuel filter , low fuel pressure ! Fuel pressure regulator bad ! Test fuel pressure an do an exhaust back pressure test ! Fuel Pressure Test Testing for plugged clogged restricted exhaust converter
Mar 18, 2015 | Cars & Trucks
Will not start but turns over
Fuel or spark plug trouble could be a cause for an engine not starting. Check for spark plug spark. Remove spark plug wire and see if the wire makes a spark on engine when spark plug wire is energized. Do not tounch engine or come in contact so that you are shocked when testing for spark plug action. Check fuel pump to see if fuel is being supplied. Disconnect fuel line and place the fuel line inside a container to capture fuel. Do not cause a fire from loss of control of fuel line during trouble shooting.
Jun 19, 2014 | 1998 Ford Ranger SuperCab
Why does my 86 2.9 l. ranger kill spark plugs
your truck is running too rich with fuel if you have a carburator have it check
Sep 18, 2012 | Cars & Trucks
Bike wont start.good spark to plugs.fuel pump working. side stand switch fine. neutral switch fine.
i have the same bike try this. Firstly check the fuel is fairly fresh, using premium fuel on this model seems to work well. drain a little fuel from each carb to remove poss water build up and get fresh fuel. if spark plugs over 6 months old or over 5000 miles change as zxrs` eat plugs a spark does not mean it is allways good. i have changed to irridium plugs and have not had problems since . before you take out plugs turn over the engine a few times then when you remove each plug they should be wet ,if one is dry no fuel so clean carb,remove plug caps before you do this and note exact location of each.good luck Bri.
Feb 13, 2010 | 1990 kawasaki ZXR 750
Can bad fuel injector damage spark plugs on a 2005 Ford Expedition? and if fuel injectors being replaced should less labor be needed for spark plug replacement?
A bad fuel injector can cause spark plug issues. If the injector does not supply enough fuel, the cylinder(s) without enough fuel will run hot, often damaging the spark plugs.
But your mechanic needs to make sure that the injector is the issue and not a fuel pressure issue from regulator, filter, or pump. Hopefully he/she has already done those checks.
As far as the labor cost being less the spark plugs wouldn't be removed during the fuel injector replacement. Even if they did, most mechanics won't cut the price. But if you are a regular customer it can't hurt to ask.
Jan 11, 2010 | 2005 Ford Expedition
Wont idle
If you did nothing to the carburetor adjustments, are using a fresh (1.5 months or less) fuel mix with the same oil/fuel ratio, are operating at the same elevation, and the air filter is clean, there is a reason your saw is acting up.
Most often it is a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor are dirty or have failed. HTH
Lou
Oct 31, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Wont start has spark , new fuel, new oil.
Is the spark plug black?
It won't run well with a carbonized plug.
Is the main jet in the carb plugged?
If the plug is dry after trying to start it.....your fuel is not getting into the engine and most likely a plugged carb jet..
Also.....Is the fuel switch working...is it in run position?
If the generator has sat for a while with fuel left in the carb/fuel tank.......the most common problem is a plugged varnished dirty carburetor in need of a good cleaning.
Always shut the fuel off and let the carb run dry (run until the engine stops)before storing.
Add fuel stabilizer to any remaining fuel or drain the tank before storing.
Oct 14, 2009 | Honda Electrical Supplies
Mini-mac 6 won't start
Engine needs spark and fuel to run. Does the spark plug fire when pulled through (remove the plug from the engine and clean around the plug base before taking the plug out)? Does it have fresh oil/fuel mixture? Try squirting a little fuel mix directly into the cylinder spark plug hole, and return the plug (if it was sparking). It should pop a couple of times--might even keep running! If it won't fire again (with the choke closed), then the carburetor probably needs attention. Has the saw been in storage for some time with old fuel left in the tank? If so, wash out the fuel tank with new fuel and pull the starter a number of times with new fuel in the tank. This engine runs fine with 40:1 or 50:1 (with right 2-stroke oil) fuel/oil mix.
Jun 28, 2009 | Garden
No fuel gettin to the spark plug
There should not be fuel on the spark plug anyway, if the plugs are firing the fuel would burn off them.
Regardless, if you suspect the fuel line is blocked simply remove the fuel line either from the petcock or carburator and blow in it to see if there is any blockage.
1) is there fuel in the tank?
2) is the fuel filter plugged?
3)is the petcock in the ON or RES position?
There should be a screen on top of the petcock that could get plugged up with debris from inside your gas tank. Drain the fuel from the tank and remove the petcock to clean the screen.
Hope this helps, pls vote for me.
Jun 07, 2009 | 2000 Honda NSR 125
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
