Question about Simplex Kaba Ilco Unican 1000 keyless lock
Www.simplex unicon 1000 lock - Simplex Kaba Ilco Unican 1000 keyless lock
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 56 Answers
SOURCE: where to go for repair to a simplex series 1000
Any locksmith worth his salt can repair one of these locks.
Posted on Jan 06, 2011
  • 963 Answers
SOURCE: Is there a repair manual
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
  • 963 Answers
SOURCE: When resetting the combination for
I can't help you directly, but I can steer you to their Tech service:
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
And Customer Service from this link:
Manuals from this site:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Lost the df-59 key and need to change the combination
For $9 you can get the df-59 key and spanner wrench from this company:
http://www.ckilock.com/Mpage18.asp ,10th item down on page
C.K.I. Wholesale Lock Supply 1-800-445-5230
Their item number SMPBC201278
Hope this helps!
Feb 22, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Hi, I've recently acquired an "Apache",
Mark, my best recommendation is to contact Kaba Ilco Tech Support with your particular problem. They are located on the East coast.
Good luck--and please provide feedback if this helps!
Aug 31, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
1-800-849-8324 (option 1)
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Can a L1000 series simplex kaba be switched to mount a right handed door
No. The Kaba L1000 is factory-handed and is not field-reversible.
That information comes from the grid found on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
under L1000/Specification/SimplexL1000 Catalogue PDF
Apr 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
When resetting the combination for the L-1000 Simplex lever or the 1000 series knob...the lock out slide does not release after it has been pushed in....can this be fixed or is the chamber malfunctioned. I...
Feb 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I am trying to change the code on my 1000 lock but do not know what a spanner wrench looks like? i just started this job and dont seem to have all the things i need to change the code.
Jan 28, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have a simplex 1000 and i'm told it can be beat by a rear earth magnet ... is this a problem?
If you take that simplex 1000 and shove it straight up your *** I dont trhink anyone will be putting magnets near it except for steve o
Jan 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Is there a repair manual available for the Simplex 1000 series locks.
aspx?id=13
Good Luck!
Nov 17, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I need a new clutch assembly for a simplex lp 1000 who do I call that has one in stock. Thanks Bruce Barrick
Nov 11, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I need a kaba ilco spanner wrench to change the combination on a 1000 series lock. where do i get it?
Sep 21, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
50 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
