Question about Garden
I have a karcher puzzi 100 and the pump For the water has stopped working, in fact it doesn't make any noise. The pump that sucks it back up is ok. Anyone know a solution?
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Kreepy krauly
If you have the round one I\'m not sure what is wrong, but if you have the one with the wide wheels in front and back, it\'s just the brushes making noise on your liner. It doesn\'t actually suck air. hope this helps.
Nov 08, 2013 | Pool & Spa
Karcher puzzi 100 not spraying
blocked pressure hose or blocked nozzle at the end of the wand
it is controlled by a pressure relief regulator which quite often plays up.
Jul 19, 2012 | Garden
Karcher just stopped working
It sounds like a motor capacitor burned up. Alternatively, a wire could have vibrated loose from the capacitor. Look, but do not touch the capacitor(s), as they can hold a charge that can hurt -- or even kill you.
The trick is to be certain they are discharged before handling. To do this, use a screw drive with a well insulated handle and touch the top of the capacitor where the wires are. The metal blade of the screw driver should touch both sides of the capacitor at the same time. Then, if there is any charge being stored, you will see a pop and that's it -- it is not discharged.
You can buy a new capacitor at any place that sells AC and Refrigeration supplies. Take the old one with you so they can match the microfarad capacity. Just venturing a guess here, but if you want one that fits perfectly back into place you may have to order it from Karcher (because those units are built in Europe I think).
2. The motor may have shorted (gone bad). If that has happened, perhaps you have some warranty. Electric motors are generally warranted a little longer than the PW in general. With Karcher, I don't know. If there is no warranty on the motor, it may be better to buy a new pw than to replace the motor.
3. The problem could be a mechanical issue with the pump/unlooader. However, I would think this would be the least likely scenario.
If what I've given so far doesn't get you rolling in the direction of being resolved, please followup here. I'll be watching. And if it does get you moving in the right direction, please take a sec to rate me. Thanks!
Don
Mar 23, 2012 | Karcher K 5.85 M Electric Pressure Washer
Frigidaire front load washer that will not start . it just buzzes. when it does start it stops after washing and leaves water in clothes asn buzzes.
it could either be a bad door switch or something stuck in the pump or a bad pump.if you set it to drain/spin will it drain out the water or does it buzz there?if it does drain i'd have to say you have a bad door switch.the model number you sent doesn't come up,you can unplug the machine,remove the hose that goes to the pump or run it before you unplug it and see if it's the pump making the sound or if the center of the pump can be removed to clean out the pump and check the pump for coins and junk,use a shop vac and vac out all the water in the tub and then lossen the hose or center of pump until water starts to leak out and vac it up as it comes out,check the pump and put it back together,add some water with a bucket or something and see if it drains out,if it doesn't drain and it sounds like the pump is making the noise you have a bad pump,if it buzzes and it's not the pump change out the door switch.the buzzing is electrical,things that could make this sound are the motor,the solenoids on the water valve or the door switch,if you can do some checks like see if it drains or try to find where the noise is coming from would be helpful.good luck and i hope this helps you out.
Oct 29, 2011 | Frigidaire ATF6000ES Front Load Washer
I am looking for someone to repair a carpet cleaning machine. It's a karcher puzzi 300. I live in Prestatyn north Wales. Can anyone help.
Karcher service is availble and must be contacted.
www.scoot.co.uk/???Wales/Gwent/Caldicot/???Gwent-Pressure-Washers-CDYM487.html
Sep 30, 2010 | Kitchen Ranges
POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
Apr 29, 2010 | Karcher K2.26 Electric Power Washer
Karcher k3.48 pressure washer appears to be seized up?
if the machine is blowing fuses then it could be the motor! if not then maby the start cupasitor has failed
Jun 01, 2009 | Karcher PSI Electric Pressure Washer
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
