Question about Maytag Washing Machines
Commercial duty maytag 2speed heavy duty 8cycle model lat9356aae leak at bottom of tub
  • 1073 Answers
SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
Posted on Apr 12, 2008
electrodynam
  • 35 Answers
SOURCE: sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Posted on Jun 06, 2009
  • 464 Answers
SOURCE: Our maytag washer model LAT9356AAE..won't spin out
check the motor pulley and the belt pulleys to see if they are hard to turn.
Posted on Oct 11, 2009
  • 714 Answers
SOURCE: kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Posted on Feb 28, 2010
jsrock516
  • 5911 Answers
SOURCE: Kenmore 90 series heavy duty super capacity plus
If your TOP LOADING Whirlpool manufactured washer (Kenmore) is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Posted on Aug 12, 2010
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Maytag model lat 9605 aae fills with water but want agitate or spin out but works fine on delacate cycle thought it was timer put one on still doing the same thing
replace the motor brushes this is common it wont spin or do main cycles but easy go it does is worn brushes
take one and and check the lenght if its less than 50mm replace them
when they get shorter the motor draws more standing current etc running hotter so....
also check the vacume switch and for and rubbish inside the drum skin
Sep 24, 2014 | Washing Machines
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
I have an Estate 8cycle 2speed washer that won't fill unless the temperature selector is set to Hot/Cold. Any ideas on what I need to check first?
I bet If you switch the water hose around it will fill on cold and not hot. Reason I think so is that hot fills and doesn't use the cold line. So either you got a bad cold valve or a blocked screen. Also Try to run the hoses into a bucket and see if they run well to eliminate the water source.
Jul 29, 2013 | Washing Machines
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Washing Machines
Kenmore heavy duty 70 series model 110-8237012
Feb 27, 2010 | Kenmore Washing Machines
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Loud, continuous buzz from Imperial heavy duty commercial freezer
Sounds like bad compressor. Turn off t/stat. If buzz starts when you turn it on then that is what is wrong. May be under mfr wty. Call Maytag to find out.
Nov 28, 2008 | Maytag MZD2766GES Side by Side...
Washing Machines Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
