Question about HP Computers & Internet
How do I rid Hd521-2w
Computer slowed down
  • HP Master
  • 27,725 Answers
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer Hope this helps.
Posted on Dec 31, 2012
Zeki tablet troubleshooting
If you have an old tablet it might just be time to upgrade.
If not there are a lot of ways you can speed up your tablet.
1. Get rid of unused and unwanted applications, they slow your tablet down.
2. Scan for viruses and spyware, they might slow your tablet down and steal your information.
3. Get rid of junk by using software like Clean Master which can be downloaded in the play store. Just install it and let it delete junk and turn of slow apps.
Aug 18, 2014 | Acer Aspire One Netbook 8.9" Notebook
Delete icons
my history icons are showing across the top of my laptop screen how do I get rid of them
Jan 10, 2014 | Computers & Internet
Computer very slow ,won't print,forever to load pages, have corrupted files
Several things can slow down the computer: overheating, spyware, not enough RAM etc. If you know for sure you have corrupted files were they corrupted by a virus? You may need to reinstall Vista.
Is it slow when you boot up in safe mode? To boot into safe mode hit (usually) F8 while it is booting up. Let it completely boot into safe mode and then reboot again. Now is if it is behaving better.
To get rid of spyware download the free Spybot Search & Destroy from the net, run the update and then run it to dectect and get rid of the spyware. Spyware tries to send info which can slow down everything.
Overheating - does it feel hot? Is the fan running and pushing air?
If it worked fine before it is unlikely you don't have enough RAM. Windows itself needs at least 256mbs to run well without running other problems.
Again if you know files are corrupted, if they are windows files, you might need to reinstall vista.
Feb 22, 2011 | Microsoft Windows Vista Home Basic Edition
My computer at start up is very slow, when I check on it my CPU is running 100%, which is why I figure it is so slow to come on line. How do I get rid of of junk on the start up?
1. You will have to clear your cache folder and your history in either IE ( Internet Explorer) and also download a program called "CCleaner: ( free) and this will allow you to do all the above in one fell swoop. Use the Google search engine to find.
2. Then download Windows Essentials ( anti-virus) from Microsoft ( free) to get rid of the malware and other unwanted programs that are slowing your PC down.
Here is the site instructions set for the "security Essentials":
http://support.microsoft.com/kb/971606
Jul 09, 2010 | Dell Dimension 2400 PC Desktop
Computer is very slow I had a bad virus so then replaced hard drive with a new one but pc is still slow
Computer slow downs are possible at all times. The only thing required is that the problem should be found and fixed at the right time.
You can scan your computer for errors here
http://www.keep-pc-clean.com/
May 19, 2010 | ASUS P5GC-MX/1333 Motherboard
My dell 610 laptop has started running slow
if you are experiencing these and unsure on what to do, better take your laptop a laptop tech, if you feel that you needed a hard drive change, then take it to a tech, have them replace your old hard drive
Nov 26, 2009 | Dell Latitude D600 Notebook
My laptop is new but it's slowing down with everything and i'm sure if its the fact we have some free protection and we havent been able to erase one trail protection or a music site the kids downloaded.
Did you go to the control panel then programs? Once there delete the programs and restart the computer. That should repair the problem of the programs still there. Check your start menu also and make sure you do not have any unneeded things starting at start up. This will slow you down also, do a disc clean up in system tools to get rid of unneeded junk on your computer.
Oct 10, 2009 | Computers & Internet
Computer is slow. Many files are duplicated but with their names changed. Example, in additions to file Documents and Settings, there is a file Docume~1. Is there a way to get rid of these extra files? Is...
it may be your profile is corrpted you can remove the other accounts by reight click on computer and go to manage and remove the other account exccpet the administrator. or it is bettre if you format and reinstall the operating systems.
Sep 09, 2009 | Compaq Presario Notebook
MY MAC LAPTOP IS RUNNING KIND OF SLOW- I DO NOT KNOW HOW TO CLEAN
Well, generally speaking there are a number of reasons that may causing a Mac computer running slow, but commonly two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system from: http://www.howtospeedupmac.com/
Jan 17, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
My compiter is too slow down to open & to close.
hhmmm maybe you should download this program that will get rid of all the bad stuff on your computer that slows it down. BUT this program is only for Windows XP :-)
http://www.ccleaner.com/download/downloading
Jul 10, 2008 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
