Question about Maytag PAV2300 Top Load Washer
Mvwb750wq1 how to remove the lid hinge on top of washer
gwshaw71
  • 83 Answers
SOURCE: To replace part #1477, female hinge part for lid
Take a plastic putty knife and insert it under head. On each side.there is a push tab now where the 2 screws used to be push real hard in and the head will pop up
Posted on Dec 02, 2007
SOURCE: my maytag performa top load
www.repairclinic.com
Posted on Nov 09, 2008
rickzilla
  • 706 Answers
SOURCE: Replace top loader lid hinge Maytag PAV 3240
Hello scottwbecket,
Not sure I have the right model for you but try this link to see if it provides exploded views of your washer ( as well as parts and electrical diagrams) If it is correct, you should able to see how the top is assembled and simply remove it. If not,you can plug in your real model number at this website and it should provde those details for you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Nov 26, 2008
tzweeb
  • 318 Answers
SOURCE: how do you remove the top of a MAH5500B Front Load Washer
you need to remove the door hinges and the screws opposite the hinges. that will allow you to remove the front panel and the you will see the latch and the top hold down screws. once you have the top up, then you will also need to remove 2 screws that hold the latch to the upper frame. it is hard to pivot the latch out from the frame but it will come out and then you can replace the assembly.
by the way.. why are you wanting to replace the latch?? any failure codes? you might also have to replace the control board as it will fail when the door latch shorts out.
if you look at the control board you might see some of the resistors that have burnt out/ shorted out. sorry but it happens alot.
if it is less then 5 years old, then you might get it fixed under warranty for free part.
Posted on Jan 06, 2009
SOURCE: How to replace hinge lid pins
I had an apprentice reply online. Read answer posted Jan 25th and my comment Jan 27th. Thanks.
Posted on Jan 27, 2009
Lid safety switch how to get out to change how to
Remove screws from rear of timer console, pull console forward and hinge it up to expose brass colored clips. Remove these clips and unplug lid switch connector. The cabinet will now hinge forward and you can remove it to access the lid switch.
Sep 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top load washer won't wash after filling
The hinge on the left side activates the lid switch. The hinge will have to be repaired or replaced.
Use a putty knife or a old CD to slide under the control panel on the right and left sides,where the control panel front meets the washer top.
This will release the clips that hold the control panel to the top cabinet.
Fold the cabinet to the rear.
Unplug the lid switch in the top of the cabinet on the left side.
Remove the brass clips holding the cabinet to the rear panel.
The cabinet will come off so that you can access the underside for the hinge and lid switch.
Jan 07, 2010 | Whirlpool Washing Machines
Replace lid switch on whirlpool washer # LSB6300PW2
The following link explains step-by-step how to access the lid switch on your washer:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
The lid switch on your washer is located by the left lid hinge under the washer casing. Simply remove the mounting screws, any ground wire and slide off the actuator rod of the lid hinge.
NOTE: In some cases, what appears to be a bad lid switch is a simple matter of adjusting the actuator rod by bending it slightly to make better contact.
If you have questions about this repair, please let me know. I hope this helps you.
Nov 27, 2009 | Whirlpool LSR5132J Top Load Washer
How do I open top of washer to replace lid switch?
If the lid is hinged along the back in line with the lid cover you just use a screw driver and pry it up from the front. SOME are not hinged and you must remove the back cover and slide lid or push lid backward to release
the clips
Oct 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Replace lid switch
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Sep 11, 2009 | KitchenAid KAWS850LE Top Load Washer
How do I replace the lid switch on kenmore top loading washer 23902? I can't seem to remove the back panel of the washer.
REMOVE THE 2 SCREWS ON TOP DOWN AT THE BASE OF THE CONTROL PANEL, SLIDE IT FORWARD A BIT AND LIFT IT UP IT IS HINGED IN THE REAR. NOW REMOVE THE TWO BRASS LOOKING CLIPS FROM THE TOP AND REMEMBER HOW THEY GO BACK UNDO THE LID SWITCH CONNECTOR(IT LOOKS LIKE IT GOES THROUGH THE TOP DOWN INSIDE). NOW GRASP THE CABINET AND PULL TOWARD YOU TILL THE BOTTOM DISENGAGES FROM THE WASHER BASE.NOW YOU CAN CHANGE THE LID SWITCH
Apr 17, 2009 | Kenmore 24032\24036 Top Load Washer
At the back of the washer just below the control panel there are two 8mm metal screws remove them there are 2 clips they will alow you to lift the top up in the front of the washer the top cover has 2 spring type holders if you slide a small screw driver in the opening and push gentle on the spring clips they will release and you can lift the top off the washer there is a screw on each hinge this will remove the old hinge then replace with new ones hope this will help
Jan 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore elite top loader electric washer
you have poor contact with the left lid hinge and the lid switch.1st open the lid and check the 2 phillips head screws on the left side of the hinge.if they are loose tighten them and try mach.if the screws are tight,the lid switch might need to be replaced or adjusted.there will be 1 screw in each corner of the back of the console facing down.remove and flip console up,if there are no screws,take a putty knife and slide under front left and right corner of console and flip console up.the lid switch will be on left.if it is not broken out of socket,adjust hinge bar underneath switch by removing switch and bending silver bar up SLIGHTLY
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
ESTATE WASHER
ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing lid..no click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer repair
on rear of console remove the 2 screws 1 on each corner..console lifts and rolls backif switch on right under lid remove clips on each side cabinet then lifts from back to front and lifts off if switch ic under left side of lid at rear make sure hinge scres are tight on left hinge and lid hinge is striking switch solid if not push hinge at curved section toward back of washer
Jun 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag PAV2300 Top Load Washer Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
