Question about Whirlpool duet Washing Machines
Whirlpool Duet bleach dispenser not working - dispenser motor working properly.
The bleach dispenser on my washer stopped emptying recently and many years of regular use. Undiluted bleach is left in the dispenser after washing. I opened the washer, ran the diagnostic cycle and the dispenser motor cycles though all 4 positions as it should. Water coming in to the top of the dispenser is directed to the holes above the bleach dispenser. This one's got me stumped.
5 Suggested Answers
SOURCE: Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Posted on Feb 05, 2008
robocop
  • 90 Answers
SOURCE: Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Posted on Jan 19, 2009
  • 311 Answers
SOURCE: Whirlpool Duet 9100 will not drain during regular wash cycle
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Posted on Jan 13, 2010
FixinFax
  • 3085 Answers
SOURCE: Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
Posted on Feb 11, 2010
WHAT IS F30 CODE
whirlpool duet front loading washer use a motor on top the dispenser assembly to switch the water in the dispenser between washing out the soap,bleach,and fabic softener compartments of the dispenser. Take a shop vac to the dispenser area. I think it is stopped up. It can have something in pump too
Sep 05, 2017 | Washing Machines
Duet Bleach dispenser not working - dispenser motor working properly
It sounds like the solenoid output of the bleach dispenser may not be reacting to the step motor that cycles it...Also check for a clog of dried out stuff just below the dispenser screen.
Dec 31, 2012 | Whirlpool duet Washing Machines
Feb 11, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dispenser full of water
believe it or not whirlpool says that's normal its in your owners manuel under dispenser because the washer mixes the bleach soap fabric softener with water for it to dispense they say its normal for water to remain but if you want to empty it there is a tab that you can press down on in the dispenser and remove it have a bowl handy
Jan 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet dispenser problem
this may be due to a faulty solenoid, if the cold water is flowing into the machine under normal use at the start, then check the solenoids as the conditioner has its own, the solenoids are just behind the body where the water pipes fit to the machine, they have 2 wires on each one, and are tested for circuit when machine is unplugged. stat there, hope i have helped
Sep 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
203 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
