Question about Ingersoll Air Tools & Compressors
Ingersoll rand mod.# 2545, builds air slow?
Compress switch was cycling out @ 170 psi. fixed that. now compresser builds air way to slow.
virgils
  • 39 Answers
SOURCE: Air Compressor, low pressure
does the compressor keep running all the time but never gets above 40 or does it turn off at 40?
if it is turning off at 40 I would try using another gauge just to be sure it is 40psi, and if that is the case then you probably have a faulty pressure switch, if the compressor is constantly runnign but won't get past the 40psi then you may have a worn out compressor, check the oil for either a low level or if the oil is dirty, if it is you may just need to drain and refill but if that doesn't fix the issue then you will need to rebuild the compressor
Posted on Oct 11, 2008
  • 98 Answers
SOURCE: i need to download a
call I.R and they will send you a manual for a small charge.
Posted on Jul 21, 2009
  • 3600 Answers
SOURCE: ingersol rand model SS3-E runs but does not build
the back pressure valve has failed it costs about 15.00 and can buy from any truck parts store That's Peterbilt trucks or any large truck stores it's one of two sizes 1/2 inch or 3/4 inch when you pull it off be sure you know which way the air flow is or it will not build up.
Posted on Nov 26, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
al_kupchella
  • 843 Answers
SOURCE: I have an Ingersoll Rand
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Posted on Aug 30, 2010
Sometimes IR 30 goes into a strained free wheeling state
Did you change the 3 phase motor out with a single phase motor? A 3 phase motor cannot be made to run on single phase.
Feb 02, 2013 | Ingersoll Rand - Rand Type - 30...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
I have a 80 gallon 5 hp ingersoll model #2475N5 serial #30T900896. Im using 10-3 wire on 40amp doible pole breaker. as its building air when it hits @50 psi it slows down. if I pull the pop off valve on...
T wo suggestions. 1- check the check valve located in top of the receiver tank by letting the unit pump up to 50 psi. shut it off and loosen the copper tube at the HP cylinder. if no air blows out the check valve is good. If it's bad it will blow until it empties the tank. If the check valve is bad replace it. 2- Tighten the drive belt. If neither corrects the problem remove the guard and rotate the pump by hand. If it's hard to rotate you have a pump problem.
May 08, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
I have an Ingersoll Rand T30 10 HP compressor that runs OK and will bulid up 150 psi without any problems. But when the pressure drops enough to kick the pressure switch, the motor won't start. just tries...
Aug 30, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Compessor cycles on and off repeatedly
Have you checked for any air leaks on all the pipes and hoses on the compressor ? Air leaks are the most common cause of continuous cycling.
Aug 23, 2010 | Ingersoll Rand 2545/7100 Electric Air...
Do not compressed air
without knowing the full problem I am thinking that you have no air flow. First check the oil level then check the regulator adjustment to make sure it is not turned all the way down
Feb 15, 2010 | Ingersoll Rand 2545/7100 Electric Air...
Air Tools & Compressors Logo
62 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
