Question about Boating
Not getting enough cooling water - Boating
    Top Expert:
  • 43,059 Answers
Replace water pump impeller
Posted on Jan 02, 2013
Why would my engine block be spewing water out under neath next to the oil filter
On an engine block there are 'Freeze plugs'. The reason for freeze plugs is to allow for expansion (E.G.--when water freezes it expands). If water does get cold enough or does not have enough antifreeze in the system the water will expand and 'pop' a freeze plug to prevent the engine block or heads from cracking. However--these plugs can fail (not cold related) causing a leak in the cooling system. Thus water circulates through the block and heads to provide cooling (water pump-radiator-heater core). Also--water pumps when they go bad have a hole that 'pops' and leaks to let you know the water pump needs to be replaced. Therefore--Location is key.
I hope this helps.
Sep 05, 2014 | Cars & Trucks
My suzuki 2005 s83 boulevard oil looks like chocolate milk.Bike has only 8000 miles.Rode and checked oil the other day was fine.I only rode 1 mile, not that hard.Checked oil today...looks bad
Sounds like water / oil emulsification. Is your bike water cooled or air cooled? If it's water cooled then you may have a gasket leak. If it's air cooled then you may not be riding the bike enough to get a good temp up inside the engine which would drive off the condensation inside the crank case / sump thereby leading to the emulsification. You say you rode an easy mile - certainly that's not enough to get the temp up enough to drive off the water. Was the bike running ok? Was it accelerating and braking ok? If so then try a cautious longer run and keep an eye on your levels. If in doubt consult a bike shop.
Jul 13, 2014 | Motorcycles
Not getting cold enough in fridge
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Refrigerators
Doesn't get cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 17, 2010 | Dometic RM2652 Refrigerator
Refrigerator and freezer not cold enough,evaporator coils look frozen
heatman101
Sep 26, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
It keeps over heating, i changed the radiator and wheel axel and nothing happened it keep getting over heated
Items to check out Cooling fans , Cooling fan relays
coolant temperature sensor,Water pump, coolant mixture.
Apr 22, 2010 | 1997 Cadillac Seville
Ive got a mildewy smell coming from my evaporative cooler how do i get rid of it?
This unit needs to be serviced. Try replacing the pads with the sponge like pads.Drain the old water and clean up the pan and pump area. Go down to a pool supply store and buy some chlorine tablets and add to the water. In fact, they make these tablets just for the evaporator units. There are 3 states to water, solid, liquid and gas,
. This will get rid of the smell.
Sincerely, shastalaker7
Oct 28, 2009 | Mastercool 67471 Evaporative Cooler Air...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Problem with cooling and fan on frige
no fan then no cooling!
try to localise the problem by removing the fan and powering it up direct from mains. if it works then problem is not with fan
Jun 25, 2008 | Refrigerators
Warm Water out of water dispenser
Usually the coolness comes from a large coil of plastic tubing in the refer compartment that stores the water. Check that the refer compartment is cool enough. Also see if running a large glass or two becomes cool again and stays cool for a while. Usually the very first 1/2 glass may be warm until the "cool" water that is stored in the coil of tubing finally makes its way to the dispensor.
Aug 25, 2006 | LG LRFD21855 Stainless Steel French Door...
Boating Logo
35 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
