Question about Microwave Ovens
Won't heat or cook
We have a GE Advantium oven. It is about 10 years old. It just stopped heating and cooking although the turntable inside the oven still rotates during the cooking cycle. Is this something that can be fixed? If so, would you have any idea how much to repair, or should we be thinking about replacing this unit. Thank you for help.
Model no. SCA 2000 BWW 03
  • Microwave Ovens Master
  • 9,098 Answers
Does it sound louder or quieter than normal?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
I'd say you have a bad primary interlock (top door switch) or that switch's mount is loose or broken, or you have a bad relay (RY2) on the "smart board".
While we repair these control panel assemblies on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty, I would advise you or someone you know to check the door switch and its mount first.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
You can order parts by entering your full model number or part number here, but if a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 19, 2009
GE Advantium Oven stopped working
Could be an open internal fuse, magnetron, or control board failure
Aug 29, 2017 | GE Microwave Ovens
Microwave just stopped cooking! all other functions (lights, turntable ..even sounds like it's working) just doesn't heat or cook!
there could be two problems with your microwave. your diode could be bad or your magnetron is no good. Its definitely one of the 2. most likely the magnetron. if the microwave is more than 5 years old, and it is the magnetron i would suggest that you replace the microwave. if you would like instructions on how to change the magnetron or diode let me know and i'll walk you thru it. although i do recommend u let a professional take a look at it.
Feb 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
How to clean GE Advantium???
Get a stainless steel "brillo pad" at the grocery store.
When you get home ... put a microwave safe container with water inside it ... in the oven. do not heat for more than 2 minutes!!!!! The resultant steam will soften the gunk. Use the stainless steel cleaner pad gently to remove the goop.
I hope this helps you
a
Sep 23, 2009 | GE Advantium 120 Convection/Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Advantium -- wont cook
The solution to this problem is to replace the magnetron. I had the same symptoms, and I got a used magnetron and replaced it. It takes some advanced electrical skill, and you have to disassemble the oven all the way to the inside stainless steel. I have the same exact model, manufactured in November of 1999.
Jan 13, 2008 | GE Advantium SCA2001BSS Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
