Question about Pioneer SX-315
Only one speaker working checked all connections they are good
I have the exact same problem....help us plz >:/
Posted on Jun 09, 2013
We got our computer fixed, because we had a virus. So everything is working but our speakers, how can we fix this?
First you may want to check if the connection is good. You may want to check that speakers jack is pluggeed in green jack of the pc. If the connection is good you may want to install again audio drivers for your pc
Mar 06, 2011 | NEC Harman/Kardon Speakers Computer...
I have been using my lg ht534sn for about 4weeks but after moving it from its fomer place to another the centre speaker and 2 other rears stoped working but but if i test all the speakers they work but...
Hi samuel
You said connections are good. Once check at both speakers and amp side for perfect contact or remove existing wiring for those speakers and re-fix. Also check for the levels individually in your HTS, also the mode you are currently in.
-sai kumar
Dec 28, 2010 | LG (SP4200K) Speaker
Sometimes it works and sometime it's not working
Must see if this can be a loose connection inthe amplifier. this can happen due to constant vibration .So open and check the power supply and the output drive of the amplifier.
Check on speaker connections, use a good soldering irron to do the job on suspected areas/
Sep 12, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Speakers have stopped working, fully plugged in, was working yesterday and has worked for the past few years. Stopped working today. Nothing wrong with drivers or anything, they should be working normally...
check if the speaker"s light glow when on, second check for ur audio cable connection to ur oc, then check ur speaker attaching it to another computer
if still no result u will have to replace ur speakers
good day
Jun 05, 2010 | Dell A225 2 Speakers
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Feb 14, 2010 | Paradigm Monitor 9 Speaker
Our two left speakers, front and rear will not
Check the connection on the back of the receiver. Check the balance setting, make sure that it's in the middle. Try another mode like stereo, you should hear left and right front only. Also, if your receiver has an on screen menu, check the dB levels for the front and rear left speakers. Good luck!
Dec 09, 2009 | Audio Players & Recorders
Why is my dvr 6300 sound goes and comes
One mistake many peoples make when it come to surround sound is that they don't hook up the right pole from receiver to speakers. Every receiver is very sensitive when it come to connecting the speakers correctly. make sure their are some kind of marking on the wires letting you know that is the positive line and no marking would be negative. hooking the wrong pole can short circuit the unit or burn it out quickly or work poorly. check your speakers connection making sure it has a good connection. check your rca jacks making sure they are good rca jacks connect to and from your systems. First I would check the wires making sure speakers connected to the wright pole from and to receiver, second check all the jacks making sure they are all good. Bad or blown speakers will also cause the rattling noise. test each speaker by using one good out put channel and swapping each speaker making sure they are not blown this way you can eliminate the speakers are bad or good. If everything check out than your receiver is defective, actually local electronic repair shop can test the unit if its out of the warranty.
Aug 24, 2009 | Kenwood Audio Players & Recorders
Center speaker no longer works
Wiggle the connection that the center one is plugged to. It starts static or playing then the internal connection is broke loose from the solder joint.
Plug another speaker to that connection. If it plays then the speaker is blown.
Feb 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Pioneer SX-315 Logo
37 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
