Question about Cameras
Cannon eos 550d error 70 - Cameras
  • 257 Answers
This is the best solution for a common problem that no one has an answer for. Not even Canon.
I'm not a camera guru, but this is a common Canon Eos issue that's been around for a while and Canon will just replace the control board. There are multiple ways this error can come about, and this looks like the only viable solution.
Give it a shot?
http://www.reikan.co.uk/photography/blog/?p=1550
Posted on Dec 31, 2012
    Genius:
  • Cameras Master
  • 1,669 Answers
Go on line to the manufacturer Canon and request a list of codes or the owner's manual for your camera!
5 Suggested Answers
SGNath
  • 170 Answers
SOURCE: My cannon rebel eos DS6041 displays error 99 when
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Posted on Sep 02, 2010
caroldon
  • 17130 Answers
SOURCE: I have a Cannon Eos
Possible failure of the lens servo system, it can be that the driver has failed ,the motor or the mechanism is failed or jammed.
If you can tap with the lens hood on your palm with the battery removed, then try with the battery inserted back to the camera.
If not remove the covers check for the motor voltage, if present motor is faulty.
If not the processor controller can be defective.
Posted on Dec 30, 2010
LogicX
  • 93 Answers
SOURCE: My new canon rebel T2i/EOS
A 5 error is the camera thinks the flash is not raising. Look near the hinge for a small button and see if it is up or down. This lets the camera know is the flash is up or down and if the button is stuck down you will hear the motor fire a few times and it will then error.
Unfortunately, this is one of the problems that starts to appear on cameras with pop-up flashes. You can hit the button and pull it up at the same time. Only other option is to send it to Canon to get it repaired.
or, Get an Speedlite like the 430EXII or 580EXII. The flash unit may make your camera bigger, but the results will be much better once you learn flash techniques.
Posted on Mar 12, 2011
  • 2976 Answers
SOURCE: is there a converter so a Tamron AF Aspherical LD 28-200mm lense fits a Cannon EOS 550D
I use B&K camera supply in New York. If it is available, they will know for sure. There are about 10,000 different cross matches possible but without having all the specs, I won't tell you something that I just 'think' is right.
Posted on Dec 23, 2012
Error 80 on my canon 550d
Have a look here at the Canon Error codes
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
Apr 21, 2014 | Canon EOS 550D Rebel T2i Digital Camera
My canon eos 550d shows error 80
ERR 80: SHUTTER
DESCRIPTION: This error occurs in the following conditions.
When the CAMERA self-check system detects that the shutter has not been fully charged (ready to shoot).
When the CAMERA self-check system detects that the shutter operation sequence has not been completed correctly.
When the built-in flash cannot be recharged after the E-TTL preflash but before the main exposure.
REMEDIAL MEASURE: Try clearing the error by turning the main power switch OFF and then back ON.
Feb 05, 2013 | Canon EOS 550D Rebel T2i Digital Camera
Is there a converter so a Tamron AF Aspherical LD 28-200mm lense fits a Cannon EOS 550D
Dec 23, 2012 | Cameras
Error 80 in canon 550D
ERR 80 is an electronic control or imaging error. Generally it is a board failure and usually the camera has to go to Canon.
Oct 31, 2012 | Canon EOS 550D Rebel T2i Digital Camera
New canon t2i. keep getting error 70. haven't even been able to take a single picture
hello. good day. error 70 is appears when malfunctions related to images have been detected.
try doing the following:
1. power down camera and remove battery
2. power down HDMI device or powered adapter
3. unplug the HDMI from the body, then plug it back in
4. power up HDMI device or powered adapter
5. insert battery and power up camera
hope this helps. is error still appear. try this link for canon support http://www.usa.canon.com/cusa/about_canon?pageKeyCode=50
Apr 29, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Hello guys, I'm an amateur just got a cannon oed 550d and I'm having some problems. When I try to shoot the Aperture and Shutter speed (that keep's changing) blink a few times, the flash goes off a few...
It's hard to say if anything is really wrong with the camera. It sounds like you haven't gone through the manual and tried the features as they are explained.
Jan 19, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Whats the difference between Canon EOAS 550D /Rebel / non rebel? Which is better camera?
Identical Canon models are sometimes marketed under different names in different parts of the world. Rebel cameras are known in America and EOS cameras are known in Europe. For example the EOS 550D is called Rebel T2i in America. They are in fact the same camera they just don't have the same name.
Nov 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
Cameras Logo
1,569 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
