Question about Dyson Ball DC24 Bagless Upright Vacuum
Dyson dc24 beater bar will not engage - Dyson Ball DC24 Bagless Upright Vacuum
EwingElect
  • 276 Answers
SOURCE: beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
Posted on Mar 22, 2009
SOURCE: Beater Bar/Brush Won't Turn
It might have tripped the safety switch when it picked up the fringe. Mine did this on a strap.
To reset the switch--recline the handle as usual, push the red start button, then push the grey beater bar button. The bar should engage when the grey button is pushed. If not, there is probably a larger problem. Hope this helps.
Posted on Apr 27, 2009
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
SOURCE: kickstand on dyson dc24 will not stand up
Solution to Dyson Ball wil Not stand up / Kickstand will not go down:
I had this problem on my Ball. The metal guides on the red foot lever had jumped out of their tracks and you have to get them back into the guide tracks on the rear wheel assemblies. I pulled on the affected wheel assembly to get the metal post on the red kickstand to reset it where it should be.
Posted on Mar 11, 2010
Dysonteam
  • 167 Answers
SOURCE: dyson ball dc24 the brush bar is not turning
Hi its Darran at Dyson.
With the machine switched off, press the re-set switch on the side of the head, making sure you push the button in as far as you can. When you switch the machine back on and lower it into the vacuuming position, the brush bar should start turning.
If this doesn't rsolve the problem, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Dc dyson 24 free repair maule
    About 1,100 results (0.84 seconds) Search Results
      ? 1:55
      https://www.youtube.com/watch?v=akGLQ7UbctY
      Sep 29, 2011 - Uploaded by AskDyson
      DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
      How to fix your Dyson Vacuum Cleaner when it loses ...
      ? 7:45
      https://www.youtube.com/watch?v=0vd3ldLXgI4
      Apr 16, 2013 - Uploaded by Chuck Fresh
      How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
      [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
    Jan 28, 2016 | Dyson Vacuums
    Brushes are not turning on my Dyson 24 vacuum - how can I fix it?
    Hi there, it's Jack at Dyson.
    DC24's cleaner head is protected by a sensor which shuts the brushbar off if something jams it. To reset your DC24's cleaner head, we would recommend following each of the steps shown in the video below. I appreciate you've already tried the reset button, but it's important to follow all of the steps in the process:
    It can help to use something like the eraser-end of a pencil to firmly press the red reset button. You should hear and feel a click as it engages. Please note, the brush bar will never rotate when the machine is standing upright, so make sure you recline it into the normal vacuuming position before testing.
    If you'd like additional assistance after giving this a try, you're welcome to contact our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or a replacement part is needed, we can also confirm if this is covered under your Dyson guarantee.
    Feb 10, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
    How to remove the beater bar on a dyson ball
    To remove, clean and replace your DC24's brush bar, please follow the steps shown in the video below.
    I hope this helps - if you need any further assistance or advice, please visit www.dyson.com and click 'Support', or call our customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Apr 30, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    Beater bar is not turning...read that you must reset beater bar. Where is the reset button?
    Sorry to hear you're having a problem with your DC24. Resetting it is simple: after checking the brushbar is free of threads, hair and other obstructions, turn the cleaner to face you. You'll find the reset button in the red recess on the left-hand side of the cleaner head. Use the blunt end of a pencil or something similar to push it in until you hear an audible 'click'.
    For more detailed information on how to clean the brushbar and check the cleaner head for blockages, you may find it helpful to visit www.dyson.com and click on 'Support':
    http://www.dyson.com/support/help.asp?article=1129&product=DC24-ALLFLOORS
    If you find you're unable to get the brushbar started again after cleaning and resetting it, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need.
    Kind regards,
    Jack
    Jul 26, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    Brush doesn't operate when the foot switch is pressed to allow the system to engage the beater bar
    I don't believe that these vacuums have a belt so the only thing that I can recommend is to unplug it, turn it over and see if there is anything obstructing the roller brush such as string, tinsel, rocks, etc. See if you can turn it with your hand without using much force. Good luck!
    Mar 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    On my dyson DC24 the beater bar attachment is not working.
    You may to simply re-set the brush bar. The cleaner head will automatically switch the brush bar off to protect the motor should the brush bar become obstructed. To re-set this, switch the machine off, stand it upright and locate the red re-set switch on the side of the cleaner head. Push this re-set switch in as far as you can and then switch the machine back on. Once lowered into the vacuuming position, the brush bar should start turning.
    If this doesnt resolve the issue, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
    Kind regards
    Darran
    Dyson Customer Service.
    Jan 02, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    BEATER BAR RESET BUTTON?
    There is no reset button for the beater bar on the DC07, DC14, DC17 or DC25. If you have a DC18 or DC24 post your question again and I'll tell you where to find the reset button for the brushbar.
    If you don't have a DC18 or DC24 call the Dyson Helpline, they will troubleshoot it and try to get your brushbar to spin.
    Jun 23, 2009 | Dyson DC07 All Floors Bagless Upright...
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    77 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
