Question about Necchi 4595 Mechanical Sewing Machine
Necchi 4595 royal series sewing machine upper case thread stuck and wheel will not move
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Posted on May 06, 2009
SOURCE: thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Posted on May 27, 2009
  • 980 Answers
SOURCE: how to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Posted on Jun 09, 2009
  • 8 Answers
SOURCE: necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
Posted on Jul 18, 2009
  • 255 Answers
SOURCE: I need a manual for a Necchi Royal Series,
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Posted on Mar 15, 2010
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
Can't turn wheel
Check the area that contains the bobbin. There might be something loose in there. While you\'re in there, clean an oil this area. Also, open the end cover (left side of machine) and lubricate the swivel arm top and bottom and wait overnight for oil penetration; you can also use a hair blow dryer to speed this up. For oiling diagram, see:
http://sewing-machines.blogspot.com/2009/11/necchi-zig-zag-issue.html
Feb 15, 2014 | Necchi 4595 Mechanical Sewing Machine
How do u thread and set tension on necchi 3205
sewusa.com has some threading diagrams
& you can also see if sewingpartsonline.com or premiersewing.com
have manual for the sewing machine
Mar 15, 2012 | Necchi 4595 Mechanical Sewing Machine
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
I need a manual for a Necchi Royal Series, #4795FA. Threading Diagram and Instructions to set the correct tensions on the Thread and foot
Happy Sewing!
Robbie
Mar 14, 2010 | Necchi 4595 Mechanical Sewing Machine
My Nechhi Royal Series Sewing Machine Has stopped working
Make sure the stop motion wheel is tight, make sure you do not have any thread stuck in the raceway area if you get a buzzing sound from the motor
Feb 17, 2010 | Sewing Machines
Have a Necchi 4595, need help
Increase the pressure on the presser bar. Usually this is located right above on the top of the machine.
May 18, 2009 | Necchi 4595 Mechanical Sewing Machine
Thread jamming, wont feed material, sewing in one place
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
MACHINE COMES UNTHREADED
your bobin case needs to be tighten there is a screw on the case turn the screw to tighten .good luck.
May 06, 2007 | Necchi 4595 Mechanical Sewing Machine
Necchi 4595 Mechanical Sewing Machine Logo
32 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
