Question about Optimus H7318 Ceramic Electric Utility Heater
Optimus heater model H-7318 stoped working
It was running and it stoped
H-5300-bk
I have the Optimus quartz heater , model H-5300-BK . The top two elements are always on in the # 2 position , the thermostat only works on the bottom three elements. Question ; Can I removed the top two elements , so the thermostat controls the total heater. fredh@bresnan.net
Nov 30, 2012 | Optimus Heating & Cooling
I need instruction manual for Magnolia 7318
Janome Magnolia 7318 (Sewing-Quilting Machine) user manual, guides and product documentations.
http://janome.imvoi.com/sewing-quilting-machine/magnolia-7318.html
Look under available documents and click on "Janome Magnolia 7318 User Manual".
This opens the user manual in PDF format.
You can save the PDF to your local computer to refer to any time without going online.
Dec 03, 2011 | Janome Magnolia 7318 Sewing Machine
I need a owner manual for a Optimus H1380 Electric Heater
There is not much details on these heaters as there is not much to be explained. The specification are available on this link:
http://www.heater-home.com/product/h-1321.aspx
Nov 21, 2011 | Optimus H1320 Electric Utility Heater
I have an Optimus H-5210 Infra-Red Heater and it's working great but last night while i slept, the pillow felt on top of it, burned a hole and i couldn't get the heater to turn back on. Is there a reset...
god please be carfull thousands of home fires start like this!!!!!!!
My guess is that a high temp cutout has opened. most likly it is not replacable.
Google search your model number / owners manual to see if there is resettable overtemp.
I was unable to locate but you may have more luck.
Remember infra-red heat warms items and objects in the room by absorbtion of infra-red waves this heater should not be near any flameable items! its designed to sit like 6 feet away from any thing and items in the room absorb heat energy then give it up to there surrounings.
please be carefull....
Mar 10, 2011 | Optimus H-5210 Infra-Red Heater
Serial#37461 zo1ff73m stoped working
http://www.rinnai.us/customer-support/manuals-literature/ i typed your numbers in but could not get a hit normaly they have good trouble shooting sections. see it you can find a model # that will work
Feb 15, 2011 | Rinnai Toyostove Direct Vent Heater:...
Heater stoped working on t5 03 model used to come
Clogged heater core, stuck closed heat valve, defective control head.
Get shop manual if your gonna attempt this repair and a good chiropractor.
Apr 06, 2010 | 1986 Volkswagen Wagon Camper
Optimus H-4438 Electric Heater
Optimus electric heater can be found on amazon, click here and take a look: Amazon com optimus electric heater. I hope this was helpful. Cheers
Jan 10, 2009 | Optimus H-4436 Electric Heater
Alarm light staying on.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Feb 22, 2008 | Heating & Cooling
Optimus H7318 Ceramic Electric Utility Heater Logo
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
