Question about Jenn-Air Ovens
What does Fr mean?
Expressions double convection oven
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
  • 1314 Answers
SOURCE: installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
Posted on Feb 13, 2008
  • 1314 Answers
SOURCE: Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Posted on Mar 30, 2008
What is a error code F/19 mean?
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
May 12, 2015 | LG 30" Built-In Double Electric Convection...
Jenn air expressions double oven
F-7 error code means that the Function Key is stuck or shorted out. You will have to replace the touch pad or if the touch pad is part of the clock, you will have to replace the clock (ERC).
Aug 18, 2014 | Jenn-Air Ovens
What does E 2 on a thermador convection thermal double oven mean
depending on the model, could be run away cook/clean temps.
Oct 15, 2012 | Thermador Ovens
I just cleaned my Jenne Aire Expressions double oven. Now its flashing and beeping "FC" how do I turn it off?
Check your wiring harness, if its OK then replace the power relay board. A faulty board can cause fan issues and pull up the error you are seeing.
Mar 29, 2011 | Jenn-Air JJW9627C Expressions Collection...
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
Fr message for lower oven
This appears to be a communications error between the control boards. There is a test mode that you can enter from the panel, which might help you diagnose the problem further:
1. Turn power at break off. Wait a few minutes. Turn power back on.
2. Push and hold "Stop Time" key for 10 seconds
3. Now you are in test mode. You can push each button to test it's function while you hold it down.
4. Push cancel to exit test mode.
If you conclude a control board failure is the problem then we may be able to save you some money. If you can have the board removed, we repair them at www.fixyourboard.com
Oct 09, 2009 | Jenn-Air Ovens
WW30430
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Ovens Logo
15 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
