Question about GE Refrigerators
GE Model No. GSH25JSXNSS ice works fine no water in the door , coil not frozen, how do I access the line in the door? does the filter supply water for ice and door water?
peyton32034
  • 410 Answers
SOURCE: GE Ice Maker not working.....Water in the door is working......
the fill tube that runs into the back of the icemaker is most likely frozen up in the cabinet. use a blow dryer to warm it up and you should be back in business..
Posted on Dec 20, 2007
SOURCE: Water not getting to dispenser, but does get to ice maker.
Hi All,
The fix to the "GE/Hotpoint Secret" frozen water dispenser problem is the Dispenser Water Tube Heater Kit, P/N WR49X10173 that can be purchased at Sears. Just a few bucks. My Hotpoint (model HSM25GFRA5A) had the same issue and GE would not tell me anything but required a technician to come out. The technician had no clue but after making some calls found the heater at Sears and ordered it delivered to me. He had to setup a return appointment but I canceled it after getting the parts and fixing it myself. The instructions are in the kit. Since most all GE/Hotpoint refrigerators (same model group of course) use the same parts/assemblies this will work for lots of folks. See pic below. If the area behind the cover looks like this it may be the part. Feel free to email me for help on this (rkjobe@military.com). Piece of cake.
Posted on Jun 24, 2008
aborcass
  • 2651 Answers
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Posted on Oct 31, 2008
RescueTech
  • 145 Answers
SOURCE: GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Posted on Dec 13, 2008
gwshaw71
  • 83 Answers
SOURCE: Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Posted on Feb 15, 2009
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
My Refrigerator makes ice but doesn't dispense water
The water reservoir is probably frozen. Remove the drawer second from the bottom and place a hair dryer on the shelf blowing on the coil of water line referred to as the water tank/reservoir. Let it blow hot air on it for 10 to 15 minutes. Try the water dispense. If the water flow is restored, set the fresh food section one setting COLDER to increase air circulation. Set the freezer to one setting to one setting warmer to circulate air that is a bit warmer. This corrects 90% of the issues related to water dispense.
The other 10% is normally the fault of the water valve.
Here is the water valve to order in case it is faulty.
Regards,
Richard Roth
http://appliancecafe.com
Oct 31, 2012 | GE Refrigerators
The water line was frozen (no ice being made and no water available in the door), so I took everything out of the fridge and freezer, let it all defrost, plugged it back in, now I have water in the door,...
Grab a blow dryer and aim it at the water tube that supplies water to your ice maker. More then likely it is frozen with ice and will need further melting to clear it out so that your ice maker will work again
Sep 14, 2010 | GE Profile PSW26P Stainless Steel Side by...
My water dispenser in my GE refrigerator does not dispense water. The same lever that dispenses water also dispenses water. I have checked the ice and water selenoids and they are working. The cooling coil...
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
Oct 05, 2009 | GE Refrigerators
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
The water won't come out of the fridge when the button is pressed. I thought it was because I needed a new filter but that's not it I changed filter the fridge is making ice fine, but no water from the...
most likely the water line that supplies water inside the freezer door has frozen up blocking the dispenser. try leaving the freezer door open for 5-10 minutes and allow the line to thaw out.
Jul 04, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
291 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
