Question about Sharp Twin Energy EC-T4660 Vacuum
Wires came undone and I need to reconnect them
Connections came loose and I can't tell which wires are supposed to go together - one of the wires is from the panel
    New Friend:
  • 36 Answers
Can you take a picture and post what you have to work with. I can help you but I haven't worked on one for a year or two so I don't remember the colors, etc.
Posted on Dec 31, 2012
Bought a Tamiya 1/14th Semi and have connected all the wires. The steering and gear shift servo wires sit really loose in the receiver so it doesn't work 100%. Just wondering what I can do to make the...
Crimp the ends a little closer together with radio pliers. Not too tight that they restrict movement but just enough to take up any slack. If the rods are still loose or too long, try to crimp a little kink in the middle to shorten the rod.
Aug 15, 2014 | Tamiya 1/14 King Hauler Metallic Special...
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Wiring diagram
Are the wires still bundled or loose?
If bundled, there are 3 connections to the motor and they make an L shape (sort of). place the motor in front of you so that 2 connectors are on the left and the last is at bottom right. The thermocoupler attaches to the bottom right, usually black or orange wire with the metal device on it. The upper left is usually a 2 white wires clipped together from the power cord and the short junction to the light bulb. The lower left is for connecting the short wire for the bulb to the black wires in the light bulb harness. Just go counter clockwise: Power, light, thermocoupler and you should be in good shape.
Nov 06, 2013 | Hoover U6616-900 WindTunnel Bagless...
Hoover HWD-20 how do I open/access the switch and motor section?
I\'ve discovered how to get the cover open.
There are four grey inserts on the top of the machine that are used to store the power cable. If you pull these up and out
(takes a bit of force) they reveal four small star screws that are somewhat difficult to access. They can be undone with a
small long handled hex nut though.
Once the screws are undone, lift the cover carefully because the switch is connected to the top. Carefully put your hand inside
the machine, having made sure the device is disconnected, and push the switch through and out the top. Then write down how the
wires are connected, red and blue on the "O" side and for the two black connectors first make a small notch with any device or
wrap some coloured tape around it etc so that you know which is which (Though technically it shouldn\'t matter). The crimp curl
overs point away from each other. Pull the crimp ends off.
There are then three slightly larger star screws to remove. You\'ve now access to the devices internals.
Do in reverse to re-assemble.
There isn\'t actually much one can do once inside the device, it\'s suprisingly well made with very little dust penetration even
after a lot of abuse. Other than the difficult to get to screws I\'m impressed with Hoover.
Nov 13, 2011 | Vacuums
Hesh DJ headphones a wire has come undone so only one of the ear pieces work. if i move the plug in about it crackles a little
Sounds like the wire that came loose is still making contact, but only when you move it around. If you can, take the earpiece apart and you will find a red or black wire shielded by braided wire. Cut the wire back some and resolder in place.
Jul 09, 2011 | Vacuums
I was in the middle of using my vacuum when it quite on me. I tried multiple things including letting it cool off for a while as I was using it to vacuum my car outside and it was pretty hot. I also...
Hi the problem you are more than likely having is with the wires that go into the vacume they are not that secure and do work loose.
now if you remove the cylinder that you empty, now you see where the wire goes into the back of the vac, well if you look at the front of the vac in the same place the wires go into the vac you will see a little inspection panel held on with star shaped screws.
you need to undo this to get to the wires
once undone you will see how the wires are secured into the vac you need to undo the connectors screws that secure the wire and remove the mains wire from the vac
now cut about 5 inches off the wire and then peel the outer cable back and cut it back so the two inner wires stick out as much as they used to, then refit the wires in the vac and close it all back up
dont do this with it plugged in as you will give yourself a shock.
when its back together check the fuse in the plug it may need changing due to the short its best if you change it anyway, then switch the vac on and see if it works
give me a shout back if it dont.
please dont mess with it if you are unsure what you are doing as you could cause harm to you and others if you dont put it back together properly
let me know how you get on ok
Aug 14, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
How do i splice the power cord back together
You will need to cut away the outer rubber insulation. Be careful not to cut the insulation on the 3 separate wires. Then you will need to remove about three fourths of a inch of insulation from each of the three wires. If you can solder, then solder the black to black, green to green , white to white. Then Tape with electrical tape each wire separately. Do a good job of taping. If you cannot solder, then go to a hardware store a buy # Wire Nuts. Take the loose end of the cord with you so as to get the right size of Wire Nut. The wire Nut repair is bulky , but secure. You are using a lot of Amps with the Steamer so you want a good job, lest the repair gets hot. Either repair I mentioned will work safely and well.
Good Luck !!!!!!!!!!!
Jun 25, 2010 | Eureka Atlantis 2591A Upright Steam Vacuum
Unit powers up but beater bar does not rotate
Have you checked the belt that drives the beater bar?
Oct 01, 2009 | Kenmore 22812 Bagged Canister Vacuum
I have a dyson dc 05 and a wire has come disconnected from the main cable inside the machine how do i get the wheel off to reconnect the cable
In the centre of each wheel there is a different colour plug. This must be removed before the wheel can be pulled off. I used a small screwdriver to prise it out. You will probably damage the plug in removing it but they are easily available online as a replacement. You will then see two screws holding the case together. You need to undo both sides plus the screw on the top.
(If you think you may have a loose connection, then it could be the motor brushes have worn out and need replacing)
Jun 26, 2009 | Dyson DC05 Cylinder Bagless Canister...
Beater bar has been rattling when running the vacuum. Stopped working all together today while vacuuming.
Hi The rattling sound is permanent and is supposed to alert the owner that the drive belt/clutch has come undone. Sadly it also means an official repair as the Animal has a protected belt that can't be repaired by the owner.
Jun 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Sharp Twin Energy EC-T4660 Vacuum Logo
73 people viewed this question
Top Sharp Vacuums Experts
jasbo
jasbo
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
