My Kenwood KR-v8050 reciever will turn on, but will not go out of stand by mode, the visual screen also is not working, what am I looking at to fix this?
    Genius:
  • Audio Player... Master
  • 1,054 Answers
Sounds like either the main power fuse is blown,or the power transformer is bad. If the fuse is blown, probably means the amp is shorted.
Posted on Dec 31, 2012
  • 4234 Answers
SOURCE: item does not work
This unit is most likely in protect mode. This occurs when the receiveer detects a problem with the output amplifier section and that section is disabled. The most common failure parts are the output transistors. Expect a parts cost between $15-$40, Add in the local labor rate for the total repair cost.
Dan
Posted on May 28, 2008
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
  • 4234 Answers
SOURCE: Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Posted on Oct 10, 2008
  • 35 Answers
SOURCE: I WAS GIVEN A KENWOOD STEREO VIDEO RECIEVER
From the info I looked at it appears to be 110 watts per channel at 8 ohms.
Posted on Jun 20, 2010
dunnbiker
  • 8546 Answers
SOURCE: My Kenwood audio video stero
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Aug 15, 2011
Kenwood KR-V7080 reciever will not play through speakers.I can still plug headphones into the reciever and get audio but not through the speakers. Tested the speakers and they still work.
If the speakers used to switch off when the headphone plug was put in the socket, suspect the socket it goes into as being the trouble. It is clearly not connecting the speakers, when the headphone plug is removed.
Aug 17, 2015 | Kenwood Audio Players & Recorders
Kenwood audio video stereo receiver kr-v8050
The audio outputs have been compromised in the unit, and they will need to be replaced.
Apr 05, 2012 | Harman Kardon AVR 45 Receiver
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
Item does not work
Dan
May 28, 2008 | Kenwood Audio Players & Recorders
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
216 people viewed this question
 Grubhead
Grubhead
