Question about Rainbow Technologies D4 Bagless Vacuum
Rainbow vacuum model D4C leaks water,
I assume it is the rubber gasket but how do I replace it.
You can buy them on line, there sticky on 1 side, you need too clean the area after removing the seal.be sure the areas clean so the seal will stick
Posted on Mar 12, 2009
    Problem Solver:
  • 9 Answers
There are no peel-and-stick gaskets for the D4. You have to peel the old one off, then use a waterproof sealant to adhere the new one on.
Posted on Aug 19, 2010
4 Suggested Answers
  • 11 Answers
SOURCE: can not get the housing off
Remove the 4 screws on the bottom of the canister, and also carefully remove the water basin gasket. You will reattach the gasket with rubber contact cement when you're finished with your repair/cleaning.
Posted on Jul 03, 2009
  • 41 Answers
SOURCE: Need wiring diagram for Rainbow D4C vacuum to
You can get a wiring diagram at http://www.rainvac.com/schematic.html
You can get all of the manuals, and the full breakdown schematics, of every model there.
If you need me to tell you which wires go where, exactly on the switch, let me know. I am a Rainbow vacuum expert and know everything about almost every model ever made.
If you have any more questions, let me know.
Thank you,
Posted on Jun 13, 2010
  • 41 Answers
SOURCE: D4 Rainbow leaking water around the water basin
Clean the water separator. Use a tooth brush if you do not have the Rainbow separator cleaning brush. It is the same thing, and works perfectly. :-)
Ralph
Posted on Jan 12, 2011
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
Why is my rainbow d4c kicking out so much dust?
Do you have the water level set right? Is there an elbow missing inside the tank?
Jul 27, 2014 | Rainbow Generic D4c And D4ce Fan Assembly....
The rainbow sat for too long on the water now wont run
So depending on how long, you may have rusted out the bearings in your motor, especially if it sat so long as to eat the glue off of your gasket.
Sounds like you may need a new motor, gasket, baffle plate and separator.
Rainbow series vacuum main unit parts
GoodVac.com
800-775-6586
Apr 14, 2014 | Rainbow E series Canister Wet/Dry Vacuum
What's the difference between the rainbow D4C SE and the D4C?
the se has a newer updated version of the power nozzle. the power nozzle is smaller.the d4c is older
than the se. the attachments are pretty much the same and the se is a darker color than the
d4c
Jul 01, 2009 | Rainbow 75th Anniversary Canister Vacuum
How do you disassemble Rainbow D4c to replace power cord? Took four screws loose but unable to see how to get housing loose...
Gently pull on the rubber gasket that seals the water tank to the canister. Although there are more screws under there - they aren't necessary to remove only to replace your cord. It is the gasket that is holding the motor flange and the plastic housing together that hinders your progress. If you're gentle about pulling off the gasket and it's in good enough shape, you can usually put it back on with some rubber cement (the same thing it is originally attached with) when you're finished. If the gasket breaks, it would have to be replaced - but not a big deal - they aren't really very expensive.
May 09, 2009 | Rainbow 75th Anniversary Canister Vacuum
Can not get the housing off
May 05, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow vacuum model SE
wow, that motor is one of the most complex in a vacuum and to repair it can be very difficult, if you want to replace it you can but it will be very expensive just for the part. the screws are hidden under that big rubber gasket on the bottom of the machine where the water tank sits. you should also replace that gasket two because it will get ruined when you tear it off.
Sep 22, 2008 | Rainbow 75th Anniversary Canister Vacuum
Rainbow d4c
Take off water tank, remove the screws to separate the top from the bottom, take out the screws inside the top and take out the plastic shell and the switch will be there.
Jan 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
Troubleshooting
That gasket is a water seal, but it can impact the suction, the top of the water tank can't seal without it.
Nov 17, 2007 | Vacuums
Vacuums Logo
905 people viewed this question
Top Rainbow Technologies Vacuums Experts
Are you a Rainbow Technologies Vacuum Expert? Answer questions, earn points and help others
