Take me through the steps to hook up my MX340 fax machine
Need to know what settings to put my fax machine on so i can fax
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Start with the Getting Started guide. You'll find other documentation here.
Posted on Dec 31, 2012
old marine
  • 1985 Answers
SOURCE: how to change fax settings to accommodate distinctive ring
Go to this link. In the search window in the center of the screen, type "drpd setup" and click on the Search button. Select the option "How do I set up DRPD". You should see step by step instructions to set it up.
Posted on Feb 05, 2009
  • 25 Answers
SOURCE: Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Posted on Feb 28, 2009
SOURCE: cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
This is a little late in response, but maybe it can help prevent some frustration for others. I had exactly the same problem, and I finally called Canon. They told me that the MP830 will only recognize and work with an answering machine, if the answering machine is plugged directly into the MP830.
This is really annoying. Our older, cheaper fax was easier to set up with a remote answering machine than this unit is. Maybe because it was a dedicated fax, and not a multifunction, I don't know.
At the moment, I'm trying to get Remote RX to function. This is when you pick up the telephone, realize that it's a fax transmission on the other line, so you type a pre-set, double-digit code into your handset to direct the call to your fax machine. This should suffice for our occasional faxes. I've had this machine for a couple of years, but I've never actually tried using the Remote RX setting. Hopefully it will work for us.
Posted on Mar 03, 2009
old marine
  • 1985 Answers
SOURCE: Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Posted on Mar 16, 2009
  • 12 Answers
SOURCE: how to hook up cable phone to work fax and
From the wall your phone cable should go into the fax/printer. Then a phone cable should go from the printer to your phone.
There should be icons next to each jack on the back of the printer which indicates where to connect the cable.
It should work from there, but you might have to go to settings and set up the fax settings such as how many singals should it ring before the fax picks up the line.
Posted on Nov 22, 2010
I'm trying to send a fax on my Canon Pixma MX340 . It rings when I dial the number, but just keeps coming back and telling me the line is busy. That shouldn't be happening at this hour. Is there...
Thank you for using fixya.........
The receiver is not receiving your fax, so the problem is coming.......
first you have to inform the receiver to receive the fax........
then try again...........
thank you......
Jul 23, 2011 | Canon PIXMA MX340 Wireless Office...
I want to connect my fax from my cannon mx340 and dont have a instuction manuel can some help me?
Plug in the RJ-11 cable at the phone jack and the MX340. Press the Fax button and then the Menu button to get the Fax Settings menu. Press the left/right arrows to highlight Fax Receive Mode. Then press OK. Select Telephone Priority Mode (you will always pick up the handset and then put it down if the call is a fax. If an answering machine is connected the Fax will be automatically answered), Fax Priority Mode (the fax will be automatically received. If you hear the machine's ringtone, pick up the handset and press Stop to answer the call.), Fax only or DRPD (distinctive ring - available extra from your telephone company). Press OK to save the setting. If you choose DRPD, you will need to teach the distinctive ring by calling the MX340 after setting the machine to listen to the ring. (See the manual.) To fax out, press Fax, put your item to fax face up in the ADF and then dial the fax number of your receipient.
Canon has the manuals for the Pixma MX340 available here: http://usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx340?selectedName=BrochuresAndManuals#BrochuresAndManuals .
I hope this helps.
Jun 12, 2011 | Canon Office Equipment & Supplies
How do i send a fax?
Hi kimberley299,
To send fax using your Canon Pixma MX340 follow the steps below:
1. First, you need to hook up a phone line from the wall jack to the lower phone jack on the back of the PIXMA.
2. Now go into the menu and set your PIXMA to telephone priority mode (manual fax recieve), fax priority mode (auto fax receive) or distinctive (fax) ring/auto answer mode.
3. To send faxes, put your originals in the feeder or on the glass, select fax mode, enter the phone number, and press start.
Hope this helps.
Thank you for using FixYa.
May 09, 2011 | Canon PIXMA MX340 Wireless Office...
What are the steps to sending a fax on a canon pixma mx340?
Check out page 89 of the manual:
http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDMwMDAwMzEwNjAy&cmp=ABR&lang=EN
If this helps you, please rate my solution!
Apr 20, 2011 | Canon PIXMA MX340 Wireless Office...
Im trying to fax.. and i keep getting an error...RX FAX INFO MISMATCH what do i do?
change fax settings from color to b&w and try again. this can happen if the fax machine at the receiving end doesn't support color fax
Apr 14, 2011 | Canon PIXMA MX340 Wireless Office...
How do you send a fax on a canon mx340
try to download manual from the following site
http://support-au.canon.com.au/contents/AU/EN/0300299101.html
If above link does not work , clickon the below link to proceed....
http://www.canon.com.au/en-au/For-You/Printers/PIXMA-InkJet-Printers/MX340
If you like solution, please rate & vote...
Thanks
San
Mar 14, 2011 | Canon MX340 AllInOne InkJet Printer
Does the line from wall go where the phone picture is? On Canon MX340
That sounds right. Most machines also have a jack for an extension phone or answering machine. That would be marked EXT in most cases.
A quick test is to use it to call any other phone, even your cell phone. If your phone rings and squeals annoyingly when you answer it, you know the fax can call out.
Of course, to fully test it, you need another fax machine to call.
Mar 09, 2011 | Canon PIXMA MX340 Wireless Office...
How to hook up cable phone to work fax and answering machine on a cannon Pixma mx340
Nov 22, 2010 | Canon PIXMA MX340 Wireless Office...
I can't fax in our out...Don't know about set up
The fax phone line goes to LINE Port
Answering machine goes to TEL Port
Jun 19, 2009 | HP 1040 Plain Paper Inkjet Fax
22 people viewed this question
jasbo
jasbo
