How do i turn on pilot on model #3509622 furnace
  • 11 Answers
SOURCE: How to reset vent safety switch
the reset is at the top left side of the furnace. take the cover off n press the red button. the switch could be failing but CHECK drafting through the furnace. hold a flame at the top of the furnace n make sure its pulling inward. u could have a blocked vent pipe or vent cap which will cause excessive heat n tip the safety switch. good luck!
Posted on Nov 24, 2009
SOURCE: Heater not heating in middle area or furnace
CLEAN!!
Posted on Dec 10, 2009
  • 221 Answers
SOURCE: The pilot light will not stay lit, I was told
Hi, this heater doesn't have a thermocouple, it uses a pilot generator which is more reliable so I doubt you need to change it out. First thing to check is that you have a clean "sharp" blue pilot, you should be able to hear it quietly roar. If it is yellow and appears "soft", the pilot need to be cleaned. The easiest way is to use a straw or tubing of some sort to blow into the pilot, gently tapping the pilot assembly. That should clean it up and heat the pilot generator properly. Tighten the the screw terminals at the control valve to assure good electrical connections and last but not least turn off the thermostat until you get a standing pilot. Good luck and stay warm.
Posted on Jan 13, 2010
TheMobilian
  • 8220 Answers
SOURCE: how do you wire the thermosat on williams wall
This heater has 2 type gas valves one valve has the thermostat built into it. No wiring needed for that puppy. Looks like this:
So I am guessing that one ain't you.
Your heater must use a millivolt gas valve with the 2 wire wall thermostat. The pilot generator does 2 things. It holds the pilot on and it produces voltages that operate the solenoid and open and close the valve when the room thermostat makes contacts. So what goes wrong with these? The pilot generator will sometimes hold the pilot flame but whn the 2 wires are touched together or you tun on the wall thermostat the whole thang just dies. That my friend is a weak thermopile generator. The other thang that goes wrong is the solenoid on the gas valve is open and therefore the gas won't come on. Their is also a fuse mounted on there that melts and kills the magnet that the generator holds in for the pilot.
Posted on Nov 05, 2011
  • 2557 Answers
SOURCE: model 3572 empire floor furnace pilot goes out when turn valve to on
Clean pilot could be blocked or its the thermocouple needs replacing
Posted on Nov 26, 2012
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
3509622 model number furnace heats up but does not blow any air out. Neither hot or cold air.
You are describing a Convection heater , they do not have any fans inside.
Nov 08, 2013 | Thermos 3509622 Heater
How do you wire the thermosat on williams wall furnace model 3509622
Nov 04, 2011 | Williams 2509612 Ceramic Mid-Size Heater
How do you lite the pilot lite on a Rheem Gas Furnace Model #rgma-125a
If I recall correctly, model number Rheem furnace you listed has electronic ignition to light the pilot, when the home's thermostat calls for heat. Is this what you're having a problem with?
Mar 11, 2011 | Heating & Cooling
Williams 3509622 wall furnace pilot light wont stay on
Might need some more information to determine the exact problem, but our guys at ComfortGurus.com might be able to help. Feel free to call them at 866-519-2461 or visit our website at www.comfortgurus.com at send us an e-mail. We also have the full line of Williams parts and equipment if you end up needing to replace any parts on the furnace. Please contact us and let's see if we can get the problem resolved!
Oct 18, 2010 | Heating & Cooling
I have a Williams Ceramic Gas Wall Mounted Panel Heater, the pilot is on but the furnance is not working
Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
Jan 22, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Jan 13, 2010 | Williams 2509612 Ceramic Mid-Size Heater
How to reset vent safety switch Williams wall furnace model 3509622
Nov 24, 2009 | Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
