Question about GE Refrigerators
Frizer is getting hot 75 f and refrigerator manufactural GE model GE profile tpx21prbc
Made by g,e, refrigerator GE profile
SOURCE: Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Posted on Oct 10, 2008
sdmc73
  • 121 Answers
SOURCE: GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Posted on Nov 30, 2008
  • 16 Answers
SOURCE: GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Posted on Jun 10, 2009
  • 13 Answers
SOURCE: Evaporator Fan Motor noise is
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Posted on Aug 26, 2010
guru_fixya
  • 944 Answers
SOURCE: refrigerator ge profile model TFH27PR water
Hi this problem could arise due to various reasons so lets find out what could it be the cause.
1)In the back of your freezer compartment is the drain hole. It's very common in GE for the drain to freeze up. With the drain hole plugged up, your freezer will continue to defrost the evaporator, but not the water in the drain hole. So the water builds and freezes, builds and freezes until it eventually overflows into the air diffuser for the fridge causing the leaky fridge problem."Heat Probe" that can be installed.This will prevent water from freezing up in the drain hole allowing it to drain as designed
2)Inspect the door seals and the sides of the refrigerator around the doors. If you see any beads of water or moisture, then the door seals may be failing to create an air tight seal which causes the cold air from the refrigerator to escape and form condensation around the doors. Sometimes you can solve this problem by applying a light film of gasket lubricant to the existing seals or just cleaning them of any debris with a warm soapy rag. If they still don't seal well after you apply lubricant, or clean them, you may need to replace the entire seal assembly.
3) If the water is coming from the freezer but you think that the defrost drain pipe is clear, then it may be coming from the ice maker. Check the ice maker for cracks in the unit's body or a misalignment of the water supply line. Make sure that the water supply spout in the freezer lines up with the ice maker's water supply cup.
4)Check the ice maker copper water supply line, your ice maker water filter, and the plastic ice maker water supply tube for any cracks, splits or connection leaks. If you find any leaks, remove the leaking part and obtain a replacement at the hardware store.
5)Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
6)If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Note:Switch you Refrigerators for more than 8 hours and let the frost melt fully use hair dryer and now switch on and check you are getting leak.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 09, 2010
The ice is blocking the air blower in the frizer and it won't deprost. The friges can't get any cold unless if I put it high.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 09, 2011 | GE Profile Arctica Stainless Steel Top...
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The frizer side has ice in the walls
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My 6 year old ge profile fridge is not cooling.
Yes it is and many tiems a few years old fridge can fail now. It is a very good idea to check with consumer reports magazine to see what is the latest best quality frideg to get as manufacturers are looking to many new manufacturing countries to get lower prices on parts to make more profits for share holders.
Lately LG, Samsung and Whirlpool have been good models as most of their models are made in one country. Check with the local retailer to see which fridges have been the best selling and trouble free.
Cheers
Al
Sep 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The frizer outside is very hot. kenmore model 71192107 year7/02
The condensor coils run around , up , down , the sides of the freezer . This heat is the heat being pulled OUT of the inside , which makes the freezer cold . Freon (refrigerant) attracts heat , which causes the frost in refrigeration . But , the heat has to dissapate , otherwise , hot gas would pump thru the system , and , no cool . A freezer does not get cold , Heat is pulled out , causing food to freeze . So , hot is good .
Aug 01, 2009 | Refrigerators
Jun 10, 2009 | GE Profile Stainless Bottom-Freezer...
My GE refrigerator is not working
in the refrigeration section there is a fan assy and damper assy, theis assy is really one kit and needs to be replaced.
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE side by side and there is frost in the frizer and it does not get cooled like it did. i defrosted it and worked good for abought a week and now there is frost in the frizer again and it stoped...
You need to check some things to eliminate the problem. Go to my site and enter model number RSS25MGN into the search feature on th left of the screen click on the 7th diagram picture. It shows the defrost heater and defrost thermostat. Also on another picture it shows a control board on back of fridge. The site offers free help and assistance. You also can contact me seabreezehvac@yahoo.com click on link below,
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 29, 2009 | GE PSS25MGN Side by Side Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
