Question about Fuji FinePix S700 Digital Camera
Need Help My camera will not power fully on. I have put new batteries in, and will not seitch on. It will, however, show the picture gallery, and menu options, but as soon as you switch to camera mode I get a black screen and it will not take any pictures...what happened?
    Genius:
  • 2,985 Answers
This appears to be a failure in the circuit board.
As such there is no repair option.
It could be as simple as a slightly loosened connection to an actual component failure
As these things as machine made there a very few repair options or if offered cost nearly as much as new camera
Posted on Jan 19, 2009
Camera is slow
Use a faster SD card. The write speed number is what you look for. The greater the number the better the card.
Mar 13, 2017 | Nikon Coolpix 3200 Digital Camera
I have minolta DiMage camera and it will not reconize fully charged batteries, it show battery as being 1/2 full and I put new batteries and it still won't reconize. I have cleaned the battery posts, but...
When you said new batteries, did you mean a fully charged battery? If so, it could be that your batteries are nat capable of holding a full charge. Otherwise, my suggestion would be to Call the manufacturer for tips or help.
Apr 10, 2008 | Cameras
Camera shows "exhausted batteries" with new ones.
i have this camera and i had the same problem
everytime i put in new batteries like 5 seconds later the battery was exhusted i tried cheap and expensive batteries but nothing seemed to work
i would recomend rechargealbe batteries because they last longer but if you prefer one-time use batteries you should change they battery type in the menu/ setup
hope this helps!! good luck
Jun 03, 2009 | Nikon COOLPIX L18 Digital Camera
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at...
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Dec 16, 2008 | Olympus FE-170 Digital Camera
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
Battery exhausted warning
Hello justplainles:
Do the others show the same problem?
Try this: RESET ALL in the menu or setup menu.
If that does not work, make sure that the in the menu (if it is there) you set the battery type to rechargeable not alkaline .
You may try alkaline batteries, if it does the same, the camera may need repair.
Some cameras will not set the battery type automatically.
Aug 25, 2008 | GE A730 Digital Camera
Nikon D80 with 400 IS lens
I think you should replace your camera battary with suaitable one.
Mar 03, 2008 | Nikon D80 Digital Camera with 18-135mm...
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
HP Photosmart 120 Digital Camera
You will need to use 2100 mAh or 2500 mAh rechargeable batteries, as others are not powerful enough. To format the card, look in the menu system (or, indeed, in the manual) for the 'format' command.
Jul 09, 2017 | HP Photosmart 120 Digital Camera
Fuji FinePix S700 Digital Camera Logo
66 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
