Question about Intel D915GAV Motherboard
Cant boot,get window saying restore last good known config etc
Hi
í have intel 915gav 512 ram 3.oghz processor,seagate 80gb sata hdd
i cant boot my pc.
if i tried to format it using new XP cd it aint work.
everytime i get 1 window saying a few options like
1 safe mode
2 last good known config
what may be da problem??
    President:
  • 948 Answers
If you are asking how to re-install Windows XP, you must boot from the cd to do that. Either change your bios settings to boot from the cd first or immediately after the POST screen press F12, then choose boot from cd and when directed, press any key to boot from the cd.
If you're asking why your pc isn't booting there are many reasons it might not boot - virus, driver problems, hardware failure. Need more information if that's your question.
Posted on Jan 18, 2009
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
To know good hard disk
I think that Western Digital Hard discs are reliable with affordable cost. But if you put a little money more Seagate offers better stability.
DDR1 or SDRAM?
Either or else I think Transcend is your solution and it is better to go to 2GB of Ram to see better improvements.
Mar 09, 2008 | Tablets & eReaders
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Intel D915GAV Motherboard Logo
131 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
