Question about Humidifiers
My westinghouse cool mist humidifier wst7503 will begin running then shut off and read error
The unit runs for a few seconds then automatically shuts off and reads out error on the screen
SOURCE: HM5081TG Reset Light won't turn off
I'm sure you've read the instructions, but in case you've misplaced or forgot them, to reset the "reset" you have to unplug the humidifier for 5 minutes.  The steps are:
1. Turn knob to "reset." 2. Unplug the unit. 3. Refill and replace tank on unit. 4. Wait 5 minutes. 5. Plug unit in and turn knob to "high."
If that doesn't turn the reset light out, re-do all 5 steps.
Hope this helps.
Posted on Dec 31, 2007
SOURCE: honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Posted on Jan 18, 2008
  • 7 Answers
SOURCE: Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
Posted on Feb 12, 2008
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
  • 8 Answers
SOURCE: aprilaire humdiifier not working
Does your humidistat have any dip switches or a small jumper wire? if it does try switching positions of the jumper or change dip switch. hope this helps
Posted on Feb 04, 2009
What is proper procedure for running vinegar through my Hankscraft cool mist humidified?
Not sure why you would want to. Vinegar is typically used to remove calcium scale that remains after a heating element or electrodes boil off water. The Hankscraft 240 doesn't boil the water off. All the minerals in the water go out the spout with the mist.
Dec 12, 2014 | Hankscraft Gerber Model 240 Cool Mist...
My Sunbeam 705 Humidifier shut down.
Generally a shut down is due to an empty water container or the float valve. If you have a can of compressed air, you can blow dry the integral ports and perhaps free up any contamination that has caused the unit to shut down.
Feb 07, 2018 | Sunbeam Humidifiers
Hello! please advise what will happen if unit is left running & is out of water?
If the float valve in the water tank is not working properly, by shutting off the unit when it's empty, Leaving it running will probably burn up the pump motor.
Feb 16, 2011 | Sunbeam Health at Home Warm Mist...
After the humidifier runs for a few minutes it just shuts off.
You might need to clean around the heating element...
we have very hard water and calcium builds up on and around the heating element and all the surrounding parts. I take it apart and pour CPR around the element and scrub with a brush .. once you get it clean it should stay running.
Dec 29, 2010 | Holmes Products Warm Mist HM5700...
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
Humidifier doesn't stop
I had the same problem if you dissasemble the unit you will probably find a capacitor between two blue wires has blown out
Mar 30, 2008 | Holmes Products Cool Mist HM3500...
Short cycling
It doesn't sound like it has failed.
The whole point of the % setting is so that the room holds at that %. When the humidity drops lower than, it will kick in. When it raises to that number it will turn off.
If the on and off is bugging you try raising the percentage. Or lower the temperature of your house. Heating will dry out the air and cause your machine to kick in.
Good Luck.
Feb 18, 2008 | Hamilton Beach Cool Mist 05521 Humidifier
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Humidifiers Logo
41 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
