Question about Kenmore Elite HE4 Electric Dryer
Dryer not Heating
Where do I find the location of the Thermal fuse on a Kenmore electric Dryer? I need to test it to find out if that is why my dryer is not heating.
  • 198 Answers
Take the bottom front panel off and the thermal fuse is mounted on the blower duct near the thermister
Posted on Jan 18, 2009
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
Kenmore dryer bought in 2004 stops heating
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
Nov 01, 2008 | Kenmore 64852 Electric Dryer
Dryer won't heat
Well first all you may check out the heating element, it is possible that your dryer isn't heating because its heating element is defective. Heating elements are not repairable. You need to open your dryer's cabinet and locate the heating element so that you can test it. and you need a multimeter to check it out. Secondly you may check out the Thermal Fuse Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you need to replace it. Post further comments for further help or information.......
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Kenmore HE5 Electric Dryer
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
My maytag electric dryer wont heat up
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
I have the kenmore elite dryer mod.# 11063032102. The problem i seem to having is that the dryer will not dry a load unless i reset it to start over
Hello there:
investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 21, 2010 | Kenmore 63942 Dryer
There is no heat to dry clothes.what do I do?
My dryer will not heat up.Investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 12, 2010 | Kenmore Dryers
Kenmore 80 dryer runs and blows air but no heat
If it's an electric dryer, then unplug the machine and check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is located inside the rear of the dryer, usually attached to or near the exhaust duct. The thermal fuse and heating element can be tested for continuity using a multimeter or ohmmeter. A lack of continuity will indicate a bad component. Sorry for your trouble and I hope this helped. Best wishes.
Oct 07, 2009 | Kenmore Dryers
I can't locate the thermal fuse on my kenmore 64612 dryer. Can you tell me where it is?
64612 is not a good model number however on most electric dryers the thermal fuse is located near the heating element and heat limit switch.
Mar 26, 2009 | Kenmore 64612 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
284 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
