Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
Hayward HD100ID no blower no ignition - Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
4 Suggested Answers
SOURCE: Problems with Hayward 100,000 Btu Heater
I am sorry to report that this is a very common problem for this heater. Here is more information than you want: http://forum.doityourself.com/pools-spas-hot-tubs/345253-hayward-h100id-ignites-but-cools-quickly.html
Posted on Jun 09, 2009
jharwell668
  • 640 Answers
SOURCE: pool heater will not ignite
Try the owners manual for these pool heaters. It will have suggestions for getting your problem corrected.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
  • 368 Answers
SOURCE: I have a Hayward HD100ID
Since this heater was only purchased last year, if it is faulty they should cover it under warrantee. If you call Hayward technical support they should be able to help you figure out what the next step is. I hope this helps.
Posted on Aug 08, 2011
Hayward hd100id blower works water luke warm
It sounds like the thermostat is turning the heater off before it gets the water to temperature. It is probably the sensor, as that is the most common cause, but may be otherwise.
Nov 28, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a Hayward HD100ID natural gas heater that I purchased last year. It's been working great up until yesterday. Today, when I plug it in and turn thermostat to max, nothing happens. I don't...
Jul 23, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a Hayward H250 that wont ignite. When I set mode to to pool the blower comes on but nothing kicks in. then i get an error code of AO.
ErrorAO means BlowerVacuum Switch Open. If the blower prover switch does notclose after the blower starts the control will stop the ignition trial go intolockout. The blower will continue to run. Automatic reset is immediate afterthe switch closes. So you need to check this.
Jun 14, 2011 | Hayward H Series Electronic Ignition...
I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pool heater will not ignite
check pressure switch,if it is faulty or out of adjustment it wont allow it to go tomain burner
Jun 17, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Igniter not working when heater is turned on
Air pressure sensor on the blower blocked or damaged and not reading the fan is on. Control board not sending spark down to the ignitor. Check the short grey tube off the blower first. If clearing it works, great. If not, you'll likely need a warranty service call. http://www.haywardnet.com/locator/
Jun 05, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
108 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
