Question about D-Link Air DWL 650 802.11b Wireless Adapter
HAVE COMPAQ 2200 CAN NOT CONNECT TO D-LINK AIR
ALTHOUGH CARD IS PUT IN, I GET MESSAGE "DLINK AIR NO CARD FOUND". HAVE TRIED THIS SAME ADAPTER IN A TOSHIBA 1500-S103 AND IT WORKS. WILL A D-LINK AIR DWL 650 WORK IN A COMPAQ 2200 LAPTOP? THANKS
  • 3 Answers
Http://support.dlink.com/products/view.asp?productid=DWL-650L1#
Follow the instructs there...
Basically - install the drivers first, reboot and then insert the card...
Posted on Jan 26, 2009
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
Www.compaq.com/argo lap top not switching on.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 09, 2010 | HP Compaq Presario 2200 Notebook
I have a DIR-615 router that I have no problem connecting my laptops with internal wireless. However, trying to connect my desktop with a DWL-G620 Wireless Adapter. It detect the network but will not...
The WPA key is the encryption key that is configured in the router's wireless settings and the wireless cards in the laptop and desktop needs to be configured with this encryption setting to allow the laptop and desktop computer to communicate with the router.
You can view the encryption settings in the router's wireless settings or on the laptop's wireless card settings and then apply these encryption settings to the desktop's wireless card (ie. the SSID and the WPA encryption).
Nov 15, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
Can't connect wirelessly, "link light" not blinking
Please check,,Are you able to go online with Modem,If yes Then re-configure your router and restart your comp and check...i hope you can connect to internet..
May 21, 2009 | D-Link DWL-650+ AirPlus Enhanced 2.4GHz...
D-Link Air DWL 650 connecting to my Dlink router
You need to go into the wireless driver advanced properties and set the SSID, WEP Key, channel and others. Wherever there is an 'auto' option, choose it.
I never got the dlink utility to work. I let windows manage it and change the device settings in advanced props.
Nagu
Oct 30, 2008 | D-Link Air DWL 650 802.11b Wireless...
Installing a wireless card in my presario 2200
The easyest way would be to buy a USB wireless adapter.
You just plug it in install the software and thats it.
I'm useing a TPLINK USB adapter, it cost me 20 €
You can also use a internal card, Mini pci most likely. very simple to install also but you might have signal - antenna problems. But this tplink has worked very well in my home and in the city.
May 17, 2008 | HP Compaq Presario 2200 Notebook
D-Link DWL-G550
Hi Atta,
The memory dump is not actually a error. It is the system making a log of the what is in the memory, at the time of a crash. The actual error was caused by something else. That DLink series of wireless adapter card, and thier drivers, seem to be very problematic. I found a lot of complaints, like this one, about them.
http://www.amazon.com/review/product/B00007LTBI?filterBy=addTwoStar
Any driver or device consistantly using 90% of your CPU is a bad investment. I am not a Dlink hater, since I use two Dlink routers.
You can go here, and get the most recent drivers for that adaper, and see if they help.
http://support.dlink.com/products/view.asp?productid=DWL%2DG550#
If the situation continues, and Dlink doesn't put out a fix, you might want to switch to a different brand. One other "fix" I have seen work on several problematic devices like this, is to disable the Dlink Wireless software, just keep the drivers, and use the Windows Wifi interface to control the wireless.
Good luck.
Jan 08, 2008 | D-Link DWL-G550 802.11g/b (DWLG550)...
D-Link Air DWL 650 802.11b Wireless Adapter Logo
172 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
