Question about Heavy Duty DeWalt 18V 6 12" Circular Saw DC390K
How do I replace the blade guard on a Dewalt DC390K saw
    Champion:
  • 304 Answers
Remove the clip behind the back blade flange holding it on to the housing and lift it up of the return spring, replace the opposite way remembering to relocate the return spring. Make sure you get the model number correct as the 390 and 390k are different.
Posted on Jan 02, 2013
How do I put the dewalt dc390 back in the case?
Have you tried to remove the battery and put it in separately?
Sep 21, 2014 | Dewalt DC390K 18v Cordless Circular Saw...
User manuel for dewalt dc390 battery powered skillsaw
Go to http://servicenet.dewalt.com/Home, put your model number in the 'Find Parts' box and hit search. There are two types of your saw, DC390B and DC390K, select the proper one and you can view or download the parts breakdown or instruction manual.
Dec 29, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
I have a circular saw that is locked and the blade won't rotate its brand new how do you free the blade?
Its sounds like the blade lock button is depressed.
looking from the rear of the unit, you should see a button between the left side of the handle and behind the blade shield.
check that. it probably is locked in the depressed position or it may be damaged.
I hope this helps.
May 18, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE BLADE, BUT I'M NOT SURE EXACTLY HOW TO REMOVE THE BLADE GUARD. I KNOW THAT I NEED TO PURCHASE THE CORRECT BLADE WRENCH TO DO THE JOB. CAN YOU TELL ME THE...
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Dec 31, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Repair spring to lower guard to spring back on dewalt 18v dc390 saw
You may be able to salvage the torsion spring that is there. Sometimes the end will break off and you can bend yourself a new end and just stick it back into the retaining hole in the housing or guard. There may be damage to the guard which will not allow you to just bend the spring to make a new joint. Either way, you need to know what you are dealing with. First remove the blade if you haven't done so already. Then remove the bumper (rubber piece) that stops the guard from returning too far. Next you will need a pick or a small flat head screwdriver. Look around the hub and you will notice a retaining ring. You will have to use the pick or screwdriver to get the ring started. Look for a little tab around the perimeter of the hub. You will have to work that tab out and make sure you keep your pick or screwdriver under it. Then work it around and off the hub. Then you can remove the guard from the hub. The spring is located under the guard and is a torsion spring. Look for damage to the guard and the housing as well as the spring. If there is any question to the integrity of the guard you should replace it. The part number for the torsion spring is 612517-00 ($1.50), the retaining ring is 150383-00 ($1.50) just in case you break it, and the guard number is 611925-00 ($6). If you have any questions please post back.
Oct 28, 2009 | Dewalt DC390K 18v Cordless Circular Saw...
Dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Aug 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Heavy Duty DeWalt 18V 6 12"  Circular Saw DC390K Logo
133 people viewed this question
Top Heavy Duty Saws Experts
Tom Chichester
ray gallant
Are you a Heavy Duty Saw Expert? Answer questions, earn points and help others
