Need wiring hookup for motherboard 06p2525
Some took all wire pluging in to board need wireing picture
    Problem Solver:
  • 9 Answers
I am not sure who the manufacturer is for a 06p2525 Motherboard. However, Sometimes there are boards that actually have the power connector, Hard Drive LED, Power LED, Reset Button, Abbreviated and printed on the board next to the appropriate pins. If not, then you are going to have to find a manufacturer name on the board. Usually you can go to the website and download the installation manual. The wiring diagram for the board is in the manual. Another option is to try going to different motherboard manufacturer sites and do a search on that part number. You may get lucky and find the board and manual.
Good luck,
Mike
Posted on Jan 19, 2009
My computer sound is not come
Make sure you sound module is pluged into the right place on the board! and that you have your cd or dvd wire pluged into the board runing to your player! then make sure you have your sound card drivers installed also! I hope this helps!
Jun 01, 2011 | MSI K9MM-V Motherboard
I took the battery out over winter and am now trying to put it back in, but can't remember how to hook the wires back to it. Please help me! Best Regards, Natalie L.
+ is red wire positive hookup. -- is black wire or negative hookup. the symbols are by the battery posts on top of battery. have a good one !!
Apr 20, 2011 | Vacuums
How to change 3 wire power cord to 4 wire
Go to this website and there will be pictures of the 3 and 4 wire hookups
Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Dec 31, 2010 | Hotpoint NVLR333EE Dryer
Had my motherboard changed by local repair shop. Both fans are now running constantly & it is deafening, also power light no longer comes on and was told it was "no big deal". Have 2 like computers,...
Ok so what fans? the case fans? the cpu fan? The power supply fan should always run. The case fan can be wired to the mother board and do an speed step system (slow to fast) depending on heat, same with cpu fan. As for the power light its just an matter of pluging in the wire from frount panel to the mother board pins for pwrled. Asus has an download for your board to get the pin outs.
http://dlcdnas.asus.com/pub/ASUS/mb/socka/sis741GX/e1766_a7s8x-mx.pdf
Feb 25, 2010 | ASUS A7S8X-MX Motherboard
Im not sure how to wire the front buttons to the motherboard.
normally the wires black connectors are marked with white text like PWR SW and PWR LED and stuff and the colors of the wires normally correspondes to the color on the motherboard.....ill look it up and see what i can do for you!
Aug 13, 2009 | Intel Desktop Board D845GERG2 Motherboard
Hooking up case wires to motherboard: ECS M925
If you look at this picture, the pins on the motherboard should be on the far left below the brown slot and above the white connector. The pins on the board are marked with tiny white letters HDD, PWR, RST, SPKR. The USB connection on the board may require a separate header, I can't find a manual to see for sure.
Apr 04, 2009 | PC Chips (M925G) Motherboard
I have a p4s333 mother board
Hey there
This is the sample picture of the M/B.
I hope this would help you a lot for reference.
Gimme acknowledge by rating me
thanx
Romy
Aug 04, 2008 | ASUS P4S333-VM Motherboard
Wiring hookup instructions for ecs 945 gct -m mATX motherboard
Hi joe, if you're question refers to ECS 945GCT-M motherboard, than goto page 12 in the manual. You'll see this
77d37bb.jpg Please read all of pg.12.
It's my guess you bought this board from powerspec. For now forget the two red wires & just hook up the case's wires for all LED's & on/off. Everything should be just fine.
Good Luck!
Mike
Jul 02, 2008 | Intel Motherboard
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
May 30, 2008 | E-Machines (308714) Motherboard
No power
Hi, to bypass the start button you will need to disconnect the wires from the front of the case where they plug into the motherboard. these are usualy marked on the mother board as to which one is which. I recomend that you use a torch and read what each wire is pluged onto. Also draw a map of the sequence, color codes and position of these wires. The one marked PWR SW is what you are looking for. Bridge this with a screw driver and see if that powers up your board. If this fails then have a close look at the capacitors on the board. These are the round things that stand up from the board at several locations. If any are bulging out the top or show signs of leakage from the bottom then its time for a new mother board. Good luck, mistyman
Aug 18, 2007 | EliteGroup K7SEM Motherboard
Computers & Internet Logo
732 people viewed this question
David Payne
David Payne
