Question about Canon iRC2380i
L have code number:00003,0001 what is it please
When the photocopier is turn on we have or it appear code number 000003,0001. please what is it <.thanks
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to reset u2-40 for sharp AR266 photocopier
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Jun 02, 2009 | Sharp AR-M205 Copier
Service code c37 appeared on my toshiba photocopier
C37 indicates Abnormal transfer belt cam motor.
U need to perform below checking:
(1) Check if the connector of the transfer belt cam motor is not disconnected.
(2) Check if the transfer belt contact/release switch is working properly.
(3) Replace the transfer belt cam motor.
(4) Replace the LGC board.
Feb 28, 2009 | Minolta CF2001 Copier
Konica 1212
Current flow to frame ground is detected. This may be caused by an external power surge or internal arcing.
To reset the code:
a. Power the copier OFF.
b. Access the 25 mode (power the copier ON while simultaneously pressing the 2 and 5 keys), P49 to 0.
IT COULD BE A NUMBER OF THINGS,,,BUT TRY THIS FIRST..
LET ME KNOW
HOPE THAT HELP
Oct 27, 2008 | Office Equipment & Supplies
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Mar 19, 2008 | Office Equipment & Supplies
Canon iRC2380i Logo
old marine
old marine
