Question about Singer 5050 Mechanical Sewing Machine
The bobbin holder has come out of the machine
How do I reinstall the bobbin holder?
  • Singer Master
  • 7,365 Answers
Here is a free manual, the information you need should be in ithttp://www.singerco.com/uploads/download/446_5040_5050.pdf
Posted on Jan 01, 2013
Problem with thread getting caught under bobbin holder
have you applied any lubricant to the bobbin holder the one that holds the bobbin? I would suggest using your manual and lube your machine. sounds to me like your mechanism is sticking.
Jun 08, 2015 | Janome Sewist 625e
I can't seem to get the bobbin holder in there correctly to get the machine to sew properly.
While I know it can only go in 1 of two ways, maybe the problem isn't in how the bobbin is in, maybe it is the route of the thread.
My assumption is you don't seem to pick up the bobbin thread and it bunches. If so the carefully follow the thread to needle you may have by passed the place you put that thread so it maintains tension.
Check that carefully, sometimes that gets overlooked.
Jan 16, 2015 | Sewing Machines
Needle hits bobbin holder
Hi, sounds to me like you haven't refitted the bobbin correctly
Regards
www.electronicrepairs.co
Dec 27, 2013 | Brother CS6000i Computerized Sewing...
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
I HAVE A HUSQVARNA 415 SEWING MACHINE. I AM LOOKING FOR THE NAME OF THE PART THAT YOU PUT THE BOBBIN INTO. I ORDERED A BOBBIN HOLDER, BUT THAT IS NOT IT.
The bobbin fits into a bobbin case (holder), the bobbin case is what you take out to put a new bobbin in. The bobbin case fits into the hook (it has a spindle in the center) which you do not take out of the machine unless you are doing maintenance. If you just ordered a bobbin holder, it could be for another machine. you must get a case made for the machine, a generic one will not work.
May 22, 2010 | Husqvarna Viking 1
The bobbin holder turns so the needle hits the holder and breaks.
Out of alignment means the timing is off...take it to a pro to have it cleaned and re-timed...if that's the real problem.
However, it seems that you think the issue is may be a bobbin holder that wasn't installed properly??
Do you have a top, side, or front loading bobbin?
Sorry...I don't understand: "If I manually turn the bobbin and holder clockwise just as the needle comes down, it goes all the way down without breaking or bending."
Do you mean that you're turning the hand wheel towards yourself...and that works properly? If so, it's probably not a timing issue.
If you have a metal bobbin case that you insert a wound bobbin into and then place that bobbin holder w/bobbin into your machine...perhaps the bobbin case just needs a slight turn in order to snap into place.
If that's not it, check your machine's manual to see what part might be missing...then, to find that small, shiny metal part, try shining a flashlight across the area where it was lost.
Apr 06, 2017 | Brother XL-2230 Mechanical Sewing Machine
Bobbin holder
Make sure the needle is in the highest position before you try putting the bobbin holder in. The bobbin holder has a metal 'finger' which fits into a 'slot' in the housing and it only goes in if you have the needle up.
Mar 31, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
22 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
