Question about GE Advantium 120 Convection/Microwave Oven
Microwave is squeaking (chirping)/grind cycle noises when plugged in! Can only make it stop when unplugged, and continues to make noise when using microwave! It is a GE Advantium convection/microwav
The squeaking is like two different squeaks. And cycle is loud chirp type squeak, grind less loud squeak, grind. First one tone of sqeak, then another tone of squeak with grinding noise....back and forth type of squeak like something is opening, closing, opening, closing.....or back/forth or.... whatever! The cycling of the loud chip squeak/grind/less loud squeak/grind is less than two seconds. The chirp noise is like either metal to metal, or rubber to metal as it's almost the same chirp squeak that my back door makes when I open or close the door...due to the rubber bottom strip I have to protect against airflow on the bottom of the door as it moves across the wood bottom frame of door. Or perhaps the loud chirp squeak is comparable to the squeak that your car windshield wipers make when you turn them on and your windshield glass is dry.......a rubber to glass type squeak noise. Thanks in advance for any advice or ideas on how to fix this!
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: grinding noise/noisy turntable
Your turntable motor is probably failing.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Normally you have to remove the bottom cover of the microwave (looking up from the stove top) and then the motor is accessible.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 31, 2009
  • 234 Answers
SOURCE: door latch hook broke on bottom, when closing
You can find the parts at a GE appl.dealer.
Posted on Mar 19, 2009
ginko
  • 19396 Answers
SOURCE: GE SPACEMAKER JVM1650
When door open the microwave should not work at all, if the turntable and light come on with the door open , if they do , then this is an additional problem with door switch and must be fixed.
Regarding humming noise and no heath, Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Microwave made noise when it was not in use.
It depends what was making the noise. a bad door switch could cause the turntable motor and the fan to fun. If is heating it may still be worth repairing. I would check the door switches. See if you notice any browning around the plastic insulators where the wires plug onto the switches. If so, you will need to replace bad switch and run new wires and connectors to the new switch too.
Aug 19, 2017 | GE Profile Spacemaker Over-the-Range...
Microwave makes sound like something moving inside
follow this steps and use the VOM , and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Jun 18, 2013 | GE JVM1490 Convection/Microwave Oven
My microwave makes a grinding noise when running and the turntable doesn't work.
Possible there is friction within the drive , the shaft or the motor. You can remove and RESET the drive. Remove the motor , MANUALLY check the motion of the mechanism which will confirm the case. You c an reset using a bit of lubrication.
Jan 10, 2013 | Microwave Ovens
Whirlpool mircowave making grinding noise
The grinding noise could be from the turntable motor, or the fan. Remove plate from oven and put a cup of cold water in, set for 30 seconds and run the microwave, if no grinding is detected it means the turntable motor is near end of life. If there is no change unplug microwave and remove top check the fan mounts tighten if loose, if straps are tight suspect the fan motor.
Jun 11, 2012 | Whirlpool Microwave Ovens
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Panasonic microwave nn-s963bf making grinding noise
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Mar 04, 2009 | Panasonic NN-S963BF Microwave Oven
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Apr 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Turntable Grinding Noise
It will need a new turntable motor. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 21, 2007 | GE JVM1660 Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
64 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
