I have a fujitsu model AOU18RD mini split ac works, heat pump operates for a short time and then it will stop working the timer light flases constantly and the red light flashes 6 times and repeats until power is shut off for a period of time.
hvac1960
  • 2133 Answers
SOURCE: Hi there, we have a
Indoor coil thermistor is short. Replace it. It's located in indoor coil ending with copper sealed tub. Thanks.
Posted on Feb 02, 2011
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
SOURCE: i have a Fujitsu ASTA24LCC
Check your filters. Manual says they need to be cleaned every two weeks under normal operation (and in my case more often during renovations). It seems it may not take much to limit air flow enough for the indoor unit to trip out. Hope this helps.
Posted on Aug 24, 2008
koolbreezes
  • 540 Answers
SOURCE: My fujitsu split type aircon is not working, the
Can you check the service manual for the diagnostic code?
Posted on Dec 22, 2009
How to reset outdoor unit fan motor 1 error-Duty error
I just had this problem. There was ice blocking the fan in the external unit. I cleared the ice, cut the power to the external unit to reset it, and everything is working fine now
Mar 26, 2015 | Fujitsu 15RLS - ASU15RLS2 - AOU15RLS2 -...
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
Fujitsu halcyon economy light and operation light flashing
I have a fujitsu DC inverter model no. ASYG18LFCA not a week old as yet, when I turn it on it works fine for 5mins. then stops and after a short time the timer and economy lights start flashing, can anyone help on this, please.
Derrick
Apr 02, 2012 | Heating & Cooling
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
Heat pump won't start, red light flashing
I do warranty work for Fujitsu ACs. You need to be more specific with the "Flashing" How many flashes of both the timer, and operation light are there? These relate to problems/faults. Take note next time and post it back here.
Feb 27, 2010 | Fujitsu Heating & Cooling
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu ASU9RLQ
Mar 10, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
