Question about Philips Magnavox 42MF521D/37 Television
Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Blue screen or while watching, display has a an approx 3 inch wide green
section running vertically (top to bottom) starting about 9 inches in from the left.
  • mario fanelli Feb 20, 2009
    I have a blue screen on all the inputs, but on the 1080 input i have a green screen and voice, but no picture. All cables are hooked up correctly. What can i do?
  • 4 Answers
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Posted on Jan 18, 2009
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Jvc rear projection tv
Do yourself a favor and dump this old TV, new ones are much better and cost is very low due to low demand.
May 18, 2012 | Televison & Video
I have an fhx2300 monitor and when watching movies on it, random pixel will start turning neon green. The computer will display blue screen saying the driver crashed and then the monitor will display a...
I would go to the Gateway website (http://www.gateway.com/gw/en/US/content/drivers-downloads) and see if your model has a driver update. Drivers Downloads listed for Vista but it should work for Win7-64 bit.
Jun 05, 2017 | Gateway FHX2300 LCD TV
I have 2 whitw stripes about 2inch wide on my
It is probably just a stuck pixel. As long as the stripes are white it can probably be fixed easily. Read the article below and see if it resolves your problem
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Dec 29, 2009 | HP Pavilion dv9000z Notebook
LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Sep 18, 2009 | LG L1930B 19" LCD Monitor
My 51 inch Magnavox rear projection has red and green overlapping
the coolant is bad inside the blue and green pix tubes-to verrify this you can remove the front edge of the screen(it pulls off-one edge at a time-take out screws to remove screen-after screen is off look down at blue/green tubes pix is bad or not there
Sep 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Pixel color fade
You are about reade to have a scan ic failure.Try to get it to a repair center asap.Have them replace the top 2 scan ic's
Jan 28, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Philips Magnavox 42MF521D/37 Television Logo
391 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
