Question about Tablets & eReaders
Need device driver for trio 4.3 tablet - Tablets & eReaders
Have a Trio Stealth -10 wont connect to the WiFi
Is wifi turned on on the tablet? If not, go to Settings>Wifi and turn it on. The device should then automatically scan for networks.
If you are able to connect to your network but then cannot actually get to the Internet you may just need to restart your router. You might get something like "Obtaining IP address" for a long time and then get "Limited" connection. Correcting this may be just a matter of unplugging it for about a minute then plug it back in. Wait 4-5 minutes for the router to boot up completely then try connecting again. Some routers are sensitive to new devices. When I had AT&T Uverse router I would have to restart it every time I tried to add a new wifi device.
Hope this helps.
Jan 03, 2016 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
How do i get my axs trio tablet out of demo mode and user terminated?
It happened to me also after I clicked on Trio Watchdog just to see what it does. Immediately I stopped the app and "removed" it, but although it disappeared from the App list obviously it was still hidden somewhere. Could not use SETTINGS to see it running and stop it because SETTINGS will not stay up also, same ....demo message.
The solution, for me, was to open the factory loaded App Permissions app and go to the startup section where I unchecked Trio Watchdog. I than rebooted the Trio AXS tablet and was back to normal.
May 24, 2015 | Tablets & eReaders
Why won't my trio stealth g2 tablet won't hard reset?
Does the device have a password lock on it.
If it does try removing this first, then attempt a hard reset.
You can access the engineers menu by holding the volume - button and then pressing the power button whilst turning it on.
Other than that the only other option is to reload the ROM with a flash utility.
But this is not for the faint hearted :-)
Aug 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Where do i find an app to upload an external bluetooth keyboard to my trio stealth g2 tablet?
I have not seen this model listed with built in Bluetooth. You could add a USB bluetooth device and it should work. Usb keyboards and mice will work for sure.
Jun 09, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Where is the serial number?
if you still have orig box, check labels... otherwise try taking back off, look under the battery
May 28, 2014 | Mach Speed Trio Stealth G2 Tablet -...
I dont have a hdmi on my mach speed trio steath g2 tablet can i hook up to the to watch nexflix
You should look at a Google Chromecast.
This is an HDMI device, that you can stream from your android to the ChromeCast connected to your TV.
They are actually quite cheap to purchase.
Then you use your tablet to control it.
It should also work with Netflix.
May 13, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How do I get a user guide for my Trio Q2 Stealth 7" tablet
(1) Go to the following webpage: www.triotablets.com/manuals
(2) Look down the left side of the page and locate the model number of YOUR tablet.
(3) Click on it and it SHOULD open as a .pdf in your browser.
(4) Save the file on yout computer, or print it out.
Feb 28, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
My trio wont work!
try your charger with some other device
if its working then there is a problem with your charging ic
or processor
go to othorize service centre
Feb 01, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
My trio tablet wont connect to wifi. It says Authentication Problem.
hi,
1.this happens if the SSID or Network name is the same in two places that you go to, but the password is not the same
2. it could be your router that needs resetting, or just unplug and plug it back up and see what happens
3. you can Delete - or tell your tablet "forget" the network in question and reconnect all new
4. if non of the above works - turn your device off and wait a little bit and turn it back on
let us know if this help
thanks
Oct 18, 2013 | Machspeed Trio DROID-7C Tablet
Tablets & eReaders Logo
138 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
