Question about Sansui VRDVD5000 DVD Recorder/VCR
Can't find manual..need to record FROM vhs to dvd. Any easy way?
Should the wires be in input or output? If we push record on dvd nothing happens. If we switch to dvd, the vhs stops.
Put it on VHS mode put the DVD in still on VHS then on the remote push DUBBING.
Posted on Jan 29, 2009
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
How do I connect my cable box to my DVD/VHS recorder & to my TV?
Cable box-----(input)DVD/VHS(output)-------(input)tv
Dec 17, 2011 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Want to transfer vhs tape to dvd
not sure why you would need an rca to s-video adapter, almost every dvd recorder and vhs has rca input and ouput.
anyway here is the basics to record from vhs to dvd you would connect the OUTPUT video (yellow) and right and left audio OUTPUT (red and white) to the dvd recorders INPUTS.
Dec 29, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Presidian DVD/VHS combo player/recorder model 16-163
make sure you are using the right input. Also the VHS might have macrovision copy protection to prevent copying. you may need a video stabilizer box if you have macrovision. If its a home movie VHS then its an input setting on your DVD recorder. it may only record from the internal vcr not an external but I am not sure
Feb 02, 2018 | Dual Presidian DVD Recorder
Waiting for input signal
It's a protected video. The VRD-MC5 will not burn a VHS or input that has been protected.
Jan 09, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Sansui VRDVD5000 DVD Recorder/VCR Logo
128 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
