Question about Toshiba Satellite M45-S331 Notebook
Get "must dump dns stash"
Ran a toshiba satelitte laptop m45-s3113 dignostic self test, got a ?blue or green screen, said something about must dump dns stash? before that, I had Kaspersky Internet security installed. it crashed, said "databases corrupt" in Kaspersky's warnings. and lost my modem at the same time. Advice form Kasp "delete and reinstall Kasp." Tried an external modem, would not recognize it. So tried a Tosh. dignostic and got the above. I feel paralized now!
  • Toshiba Master
  • 4,924 Answers
I suggest to forget about diagnoses and just reinstall the operation system again from scratch ..using a boot-able disk or flash usb ..and clean the hard drive completely .. At least the C drive ...just format it during installing ..This will make it work if it is nothing physically wrong .
The modem is probably just disabled or missing drivers..or blocked..I see no reason to be affected ..reinstalling a clean os ..will fix it too ..
I suggest to use just the programs you really need ..and get read of all tools from Toshiba ..and use a more reliable security ..like Microsoft essentials one ..Its free and not invasive ..and Im really satisfied so far with it ..
If you run windows xp ..it will ask you to update a few things before let you install it ..Just click on the suggestion and download those fixes..
Posted on Jan 07, 2012
MY TOSHIBA SATELITTE C850D IS NOT BOOTING
Have you tried a System Restore/recovery? Will it boot to Safe Mode? If you remove ALL media DVD,CD,USB, unplug, remove battery, plug in, reboot, any change? Remove the HDD, test.
Mar 11, 2013 | Computers & Internet
Pxe e61 media test fail check cable
what error message are you receiving on the blue screen? if it resets to fast start typing f8 at boot and in the advanced menu, toggle down to do not restart on system failure. write down the hex code (0x00XXXXX) and report back. What version of windows are you running? have you tried to press f2 or f1 or whatever key it is to enter setup on your laptop @ boot and disable network boot?
Jun 11, 2012 | Toshiba Satellite M45-S2653 Notebook
I have a Toshiba Satellite M45 and the monitor no longer works. there are some lines on the screen (left) and the rest of the screen is black.
Can you tell us please, what - recently - happen to the lap? have it been shocked, dropped down ,,, ?
To test, u can plug external monitor in the VGA-port, turn ON the laptop, after a minute, toggle the display once, or twice, or 3 times to change the display path to the external monitor.
Tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite M45-S2652 Notebook
Where can I find latest bios and drivers for a toshiba m45-S2652 without having to buy some tool or something. Drivers should be free!!
Hi wesley_littl,
You can download Toshiba Satellite M45-S2652 drivers here for free.
--> please make sure to download the driver that matches your operating system.
--> just select your operating system on refine search by.
Hope it helps,
Thank you for using FixYa.
Jan 27, 2011 | Toshiba Satellite M45-S2652 Notebook
When i was booting up the computer..It just died out and never came back on.
Check your battery and ac adapter before going too far into the technical side of the laptop.
Toshiba use what is known as Power On Self Test. (Most do actually), it runs a programme before the BIOS starts and checks the periferals, keyboard, screen DVD etc.
The lights should at least flash at that point.
You may have faulty memory or a system error.
Please let me know what you find.
Hope this helps.
Oct 31, 2010 | Toshiba Satellite M45-S355 Notebook
Toshiba M45-S3591 Laptop
Well, you have to reinstall your Operating System.
It is probably a virus that does this and the safest way to get rid of it is to reinstall the Windows.
Here is a link that can help you after the reinstallation process:
http://www.fixya.com/support/r4213055-quickly_reinstall_operating_system
If you need further assistance, post a comment
Mar 29, 2010 | Toshiba Satellite M45-S3591 Notebook
Toshiba Satellite M45-S165 laptop not turning on at all.
Try taking battery out and powering up, then try resitting memory and then the same for the hardrive,
Let us know
Jan 07, 2010 | Toshiba Satellite M45-S165 Notebook
Satelite Toshiba M45-S165. WOrked fine, now won't boot
To sure the battery problem or bad. try to change another battery for testing only befor you replace at all.. I thing this over charging of the battery. then the battery became damage or bad.. to sure change other battery..
Thanks
May 11, 2009 | Toshiba Satellite M45-S165 Notebook
Crash dump blue screen
If warranty - call it in. Otherwise it sounds like a classic case of bad ram. Find a friend with similar ram in his/her laptop and do a test swap to see if symptoms repeat. Then replace the ram. Far more common in HP's then Toshiba, but it happens for no reason. Basically it's a page in or out error with the ram causing windows to "freak out".
You can get a good selection of ram from Tigerdirect.com or newegg.com.
Apr 28, 2008 | Toshiba Satellite® P105-S6084 PC Notebook
Motherboard
There are any number of Toshibe motherboard sources on the Internet and if you are comfortable with E-Bay they had a number of M45 boards listed, looks like from about $190 and up. Did you post here in anticipation of someone having a board to sell you? If so E-Bay can handle that much better I would think since I'd have to be a seller with exactly what you want, happen upon your question and we make a deal. Could happen but not likely on a trouble shooting sight. Sorry wish I could help.
Feb 22, 2008 | Computers & Internet
Toshiba Satellite M45-S331 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
