Hotpoint ultima wt960 is blocked - Washing Machines
Malcg
  • 32 Answers
SOURCE: hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Posted on Apr 13, 2008
  • 5 Answers
SOURCE: Hotpoint Ultima (WT960)
this worked for me:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
IFIXALL
  • 868 Answers
SOURCE: Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
Posted on May 26, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima wt960
F10 means that the water level switch is not sensing the correct water level, this can be caused by faulty switch, a blockage in the pressure system, a blocked drain pump or filter.
It is a process of elimination I'm afraid.
Please rate my suggestions to solve your problem.Thanks.
Posted on Mar 02, 2009
SOURCE: how do you remove the child lock off the washing machine
Great Thanks for that
Posted on Apr 20, 2009
I have a hotpoint wt960 and it keeps cominose this meang up with h20. what d
H20 is indicating a problem with the incomong water supply.
Check the inlet hose/s for kinks or restriction.
Make sure water pressure is ok, and the valve is fully turned on.
Check the filter in the inlet valve is not blocked.
Mar 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
I need to download a user manual for a hotpoint ultima wt960 please
Go to---
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on--
HOTPOINT USER MANUALS
Ithe search box, enter your model number, and download the instructions.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
How do i reset my hotpiont ultima lcd wt960 washing machine?
I have a hotpoint wt960 i did 1 load of washing, turned it off. Put next load in then it would not turn back on. any ideas???
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Mar 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
6,694 people viewed this question
Top Washing Machines Experts
