Question about Sony Cyber-shot DSC-S750 Digital Camera
Resolution is low!
The camera is set to VGA, how to change it back to 7.2 Mpixels?
  • 10,594 Answers
Easiest was is go to Camera Menu -> Initialize -> Yes.
Camera will reset and select factory default settings.
Other way is set camera on camera-mode, press menu and find picture resolution setup, you will see fine, standard, vga, email options there, select desired option and done.
Posted on Jan 18, 2009
I updated my windows when my laptop resolution was automatically changed. How do to recovery my default landscape resolution setting.
You can go to display properties by right clicking on the desktop. (Please do not select any desktop icon).
In the resolution option you can set your landscape resolution as required.
Thanks
Amar
Sep 21, 2011 | Computers & Internet
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
EVERYTHING on monitor is upside down
login in vga mode and change vga resolution settings. For open vga mode restart your computer press "F8" button it shows some modes in that select vga mode and press enter. then change vga resolution in display properties> settings change to low resolution and restart your system
Jul 07, 2010 | Dell Dimension 4700 PC Desktop
My compaq computersceen says input not supported
i think your cpu settings you changed to high resolution. That resolution is not supporting by your monitor. If you have another monitor connect to that monitor to your cpu and change lo some low resolution. If monitor is not there try to boot in vga mode for that mode you need to press "F8" button on booting. It show you some modes select vga mode and boot and change the resolution and restart your system
Jul 05, 2010 | Computers & Internet
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Canon Rebel EOS - Pictures download read Low Resolution
Canon Digital Rebel cameras let you set the image resolution from small jpegs (low resolution) to large jpegs (high resolution) to RAW (best quality, but require post-processing in your computer before you can print them). It's possible that as you were getting to know your camera you accidentally set the image size and quality to a low setting. Now you just need to change it back!
You make this change in the on-screen menu, under the camera menu (first menu, with a camera icon), first item (Quality). Although Canon no longer has the manual for this camera online, you can see This Review Page for more details on where to change this setting on your camera.
Dec 18, 2008 | Canon Digital Rebel / EOS-300D Digital...
DSC T20 poor image problem
If you took the images at 8MP or 5MP settings, then normally you have a high resolution picture, was the picture clear at the cameras LCD monitor? As you said its like low res in your PC, please check the image file size 8MP resolution will be approx. 3Mb size, if its about that figure, then the problem is in the camera, if the file size is about 500K maybe its in the camera settings, PC cant affect resolution, unless you only have VGA card and monitor, hope this will help, thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Sony Cyber-shot DSC-S750 Digital Camera Logo
108 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
