Question about Microwave Ovens
GE Microwave Oven PEM31BMC02 mesh on glass door makes it impossible to clean. Do you have a solution?
5 Suggested Answers
GARYDALE
  • 15 Answers
SOURCE: GE XL1800 Door
For one if stuff had got between the two glass plates the you need to replace that seal that can be harmful for any one standing in front of the microwave when it is running.
Posted on Sep 05, 2006
SOURCE: How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Posted on Jan 31, 2010
OK, I'm no handy man and I just figured out how to do this. Open the door and remove the black plastic cover surrounding the inside glass. I used a regular flat head screw driver to pop this out.
Now I removed the 3 screws holding the inner panel against the glass on the front door. After removing the screws, the inner panel is held in place by a series of plastic clips. Go around the perimeter and pop the plastic clips out so the inner panel including the mesh comes out of the door.
Now you have complete access to clean the inside of the glass door!
I found it easier to do this operation with the door completely off the microwave, but you should be able to do this with the door in place too.
Posted on Jul 25, 2010
I have a GE Spacemaker over the stove microware. I found that after my wife did her sscrub job to remove grease from the outside glass and the wire mesh, the wire mesh apparently trapped some water inside or under the mesh - it looked white & cloudy. I used the hair dryer and after a 10 minute of blowing on higfh heat, the condensation dissappeared.
Posted on Oct 06, 2011
We have a new 24"Dacor
The service manual is here and the parts list is here.
That mesh is the door screen which prevents microwave leakage.
It must be intact or replaced, or a fire hazard exists.
You can order Dacor parts by part number from the Pros here.
Feb 26, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Can you use a microwave if the glass on the door is broken?
It is not advisable. The door is a critical safety part of the microwave oven. The glass being gone will allow heat in areas of the door not designed for heat. The glass also is a support for the safety mesh that contains the microwave energy to the cavity.
May 12, 2010 | Westpoint TV-201 Microwave Oven
Cannot clean the inside door between glass and mesh - any ideas?
Unfortunately it is not possible to do this without dismantling the door. The mesh is very important for containing microwave energy in the oven cavity. If the door is dismanteled it is important not to damage the mesh and to have the oven tested for possible leakage after it has been re assembled.
Jan 07, 2010 | Whirlpool GH4155XP Microwave Oven
Model 665.61639100
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The mesh screen on the inside door has a hole in it..
would suggest replacing door for safety purposes only," it could be fine as far as resisting waves",but never sure for how long or if it realy is. An old saying makes sense," Better safe than sorry".
Apr 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Clean between mesh and glass on microwave door
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 04, 2008 | Whirlpool MH7140XF Microwave Oven
Can't clean microwave oven door
you can change this part easily... if you want a fresh look, or using a degreaser that is available in home depot...
cheers
Nov 24, 2008 | Microwave Ovens
Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
GE XL1800 Door
Aug 27, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
