Question about Whirlpool Washing Machines
Whirpool duet model WFW9151YW00 will not spin
First the machine was banging now it will not spin
  • 67 Answers
SOURCE: duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Posted on Mar 20, 2007
  • 240 Answers
SOURCE: washing machine doesnt spin and no drain
check lid switch. common for whirlpools
Posted on Mar 14, 2009
SOURCE: duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Posted on Jun 19, 2009
  • 44 Answers
SOURCE: my whirpool duel washer agitates or washes but
I would check onj the microcomputer in your machine . many times the cpu takes a dump and acts that way. Try ebay they have some used parts that work and you can get them cheap
Posted on Dec 09, 2009
Testimonial: "Thanks"
  • 1382 Answers
SOURCE: whirpool duet washer - error code f35. shuts off
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Posted on Jul 27, 2010
Whirpool duet model#WFW9300VU02Why doeswasher clangs and bangs in the spin cycle
the spider gear is broken,it would be cheaper to replace the washer than have it repaired,you either overloaded the washer or used to much detergent,you should only use two tablespoons of h.e. detergent in a front load washer or you did both,if you look at the back wall it looks like a peace sign,that's where the gear is
Jun 23, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool duet dryer control lock light is on and my dryer will not work
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Fi pops up on my front load whirpool duet model wfw9200sqoo. and wont finish the cycle. unless we manualyput in rense and spin mode and somtimes unplug it, and reset spin mode,, and somtimes like today...
Frontload failure code
F-1= EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU. Bummer.
DUET SERVICE MANUAL AND MORE HERE
Jan 25, 2011 | Whirlpool Washing Machines
My whirpool duel washer agitates or washes but
have you replaced the motor control. i had this happen 1 year ago and had to have it replaced. i am having the same problem and have done some testing but have not found anything else. you can buy this part from whirpool for about $160 delivered to your home. this is exactly how it acted the 1st time it went out. some loads would spin out great and the next load would be wet.
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
97 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
