Question about HP Pavilion a6110n PC Desktop
Fan runs continually
The fan runs hard when watching videos. Also high CPU usage
  • HP Master
  • 27,725 Answers
Adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit b> Hope this helps.
b>
Posted on Dec 31, 2012
3 Suggested Answers
adnanbhatti
  • 1188 Answers
SOURCE: I have a HP M1270N Media Center PC. The CPU Fan
The CPU fan is designed to run constantly to prevent the CPU from overheating. The speed depends on temperature condition of the room; slow in cold and fast in a hot room. However if you suspect that it runs too fast them try re-seating the CPU. WARNING: Re-seating should only be done if you are know how to do; don't experiment.
If it is running noisy, you can apply one or two drops of machine oil to the fan's spindle.
Other reasons include deposits of dust; use a blower to remove dust from the heat-sink.
To make sure you CPU is not in a critical state, log in the BIOS and in the hardware monitoring tab check the CPU temperature. It should be near 60 deg Celsius or 140 Fahrenheit.
One thing more, do not apply thermal grease in excess; its a conductive compound and can short the motherboard if it melts and deposits on the motherboard due to high CPU temperature.
Posted on May 30, 2010
  • 11800 Answers
SOURCE: the hp m 7170 n
No, find out which program is using all those resources (use Task Manager for that) and uninstall it.
Posted on May 11, 2011
Dell Inspiron1410 running 50% CPU usage with no other processes running in background. This after a nice repair install of Windows XP professional. High fan noise and heating up! Thanks
Hello Saman Tarik,
Task manager may say there are no other processes running but if you look in the next tab, "Services" you will find there are many things running.
The processor will run at a lower percentage when it is not busy.
As for running hot, I would suggest that the heat sink fins need cleaning out, I was surprised at how much fluff had accumulated in them, preventing a good air flow.
I have upgraded my processor from 1.5Ghz to 2.5Ghz which runs hotter so I bought a ZALMAN ZM-NC1500 USB and the hottest my CPU has reached is 41 degrees when both cores are running at 100%.
I hope the above information is of use to you.
Kind regards,
Ron.
Nov 21, 2013 | Dell Inspiron 8600 Notebook
DELL INSPIRON 1410 idle process takes high processor usage and heats up my pc
If running Windows OS - there could be several background processes running causing this higher CPU usage.
Hitting 'CTRL/ALT/DEL' will bring up the task manager (Win98/WinXP) or a Menu which has task manager (WinVista/Win7/Win8), you can then see what background programs are running.
Usage cpu 100%
The high CPU useage could also be the virus scanning program running and if your hard disk has a lot of files, data etc. it would take a lone time to complete.
Removing unwanted files and programs will make the virus scanning complete its task quicker.
You should also carry out hard disk maintenance at least onec a month Ie Disk Cleanup and Defrag to remove temporary unwanted files and Defrag will make your files contiguous so the hard disk does not need to work as hard and efficient.
Jun 01, 2012 | HP Computers & Internet
I have dell optiplex gx280 computer.i am facing problem of CPU high fan speed when i turn on the PC.it goes to full noise like a jet fighter and nothing get appeared on the screen and fan continuously gone...
dells usually go full blast on power up then slow down to normal,sounds like fan is not responding to slow down signal i would try replacing fan, its got to be a dell fan
Jan 08, 2011 | Dell Optiplex GX280 (99301) Motherboard
No start up and continuous repeated long beeps?
Hello
Here are the bios beep codes:
1 long, 2 short
Video adapter error
Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly.
Repeating (endless loop)
Memory error
Check for improperly seated or missing memory.
1long, 3short
No video card or bad video RAM
Reseat or replace the video card.
High frequency beeeps while running
Overheated CPU
Check the CPU fan for proper operation. Check the case for proper air flow.
Repeating High/Low
CPU
Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
Check computer beeps and act according to suggestion
Hope it helps if so do rate the solution
Dec 20, 2010 | Compaq Presario Notebook
Seems my toshiba satellite lap-top is over heating, how do I get to the fan to clean it? Model number: psafgu-02k001 serial; x7253530q
If your fan is running OK, then it probably doesn't need cleaning.
I have a satellite A350 and it pumps out a LOT of heat but that doesn't mean it's overheating. It's more likely your CPU usage is very high, which makes it very hot.
Turn on the CPU Meter in the Windows sidebar and close all applications. Watch the CPU usage (the larger front meter) for about 20-30 seconds. If the AVERAGE level when running no other applications is over 40% or spiking up at 90 or 100% then you are probably running too much junk in the background, or you have a virus.
Oct 14, 2010 | Toshiba Satellite A215-S5837 Notebook
High CPU when using windows media player online. i dont think fan is working is that the problem
High CPU Temperature = Bad fan
High CPU Usage = Virus or corrupt program
If this helps please vote for my solution.
Dec 18, 2009 | HP Pavilion (PN153AAR) PC Desktop
I can not download form HDC-SD20 use by HD writer
I have same problem. I have Panasonic HDC-TM20 video camera. It came with HDWriter ae 1.0 software. I have ACER alptop, running XP. Everything was running fine for months, but now I cannot transfer from the video camera to the hard disk on my computer. It attempts to do it, but then it just does nothing for ages. CPU usage shoots up high. When I kill the application, it does die, but process continues so I need to re-boot mt laptop before I can load it again. Is these any one out there who has resolved this issue?
Nov 12, 2009 | Panasonic HDC-SD20 High Definition...
My Macbook fan keeps running
There may be high CPU usage by some program. It would be normal for the fan to run if the CPU usage is high. Check the Activity Monitor (found in utilities) to see if something odd is going on.
I had a problem where iPhoto quit working, and somehow was using 90%+ of the CPU. I could view the photos, but some operations did not work and the only way to exit was Force Quit. I had to remove and reload iPhoto.
Mar 26, 2009 | Apple MacBook Mac Notebook
CPU usage very high, mouse very slow man
hi,
you haven't mentioned whether your mouse started moving after you deleted the applications..
Anyway to lower your CPU usage, you can do the following...
1. Run 'msconfig' without the inverted comas in the run dialog box. ( start--> run )
2. Select the startup tab... you can disable all application at startup to load the system faster. or you can select the application that you thing is unnecessary. this needs a restart.
3. Next try to press Ctrl, Alt , Del at the ssame time to launch the task manager. First you will be seeing the application that is running. Go to the next tab that is the Processes tab. under this you will see all the processes that is running and utilsing how much resources . Below on the status bar of that window you will see the cpu usage... Now identify the processes that has the highest memory usage... right click and select end process tree. the process will be stopped. Remember not to end the explorer.exe process. Most resources is utilised by Anti-virus softwares like norton, also by web-browsing and graphics opertaions....
hope to get rated as fixya!!
regards
bzoy..
Jan 03, 2008 | Acer Aspire 3000 Notebook
HP Pavilion a6110n  PC Desktop Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
