Question about Whirlpool WFC7500VW Washer
Wfc7500vw will not go into diagnostic mode
Door will not unlock at times and will not lock at other times
2 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: ERROR CODE F28
Unplug the machine at the mains. Remove the detergent tray. Reach all the way back with your hand in the slot where the detergent tray normally fits and feel for a lever. When you find it pull it forward. Then replace the detergent tray. Plug the machine back on and the error code will have reset and the machine will be useable again.
Posted on Oct 05, 2009
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Mar 18, 2016 | 2004 Ford F150
What is f-22
F22 means you have a door lock problem you need to unlock your door to correct the problem
May 22, 2014 | Whirlpool WFC7500VW Washer
Trailblazer dor locks
try this procedure, close all doors, insert key into ignition switch,press and hold door unlock switch,turn ignition switch from on to off twice, release door unlock switch,doors will lock then unlock to confirm programming mode.now simultaneously press and hold the lock and unlock buttons of the first remote transmitter after approximately 15 seconds doors will lock then unlock to confirm remote transmitter programming. if all fails to work take vechicle to dealership, they will have to use diagnostic equipment to reprogram remote.
Feb 12, 2012 | Cars & Trucks
Had battery replaced but radio, power locks, and trunk button doesn't work. what do i do?
DEALERSHIP HAS TO RESET RADIO BUT YOU CAN REPROGRAM DOOR LOCKS BY CLOSING ALL DOORS.INSERT IGNITION KEY IN IGNITION SWITCH.ACCESS DATA LINK CONNECTOR ON DRIVER SIDE FASCIA JUMP DLC TERMINAL 1 AND GROUND TERMINAL 1 MAY ALSO BE GROUNDED USING DIAGNOSTIC EQUIPMENT CONNECTED TO THE DLC.SWITCH IGNITION SWITCH ON AND BACK OFF POSITION ENSURE DOORS LOCK AND UNLOCK INDICATING PROGRAMMING MODE ACTIVE.PRESS ANY BUTTON OF EACH REMOTE TRANSMITTER THREE TIMES WITHIN TEN SECONDS. WAIT 1 MINUTE OR REMOVE JUMP LEAD TO EXIT PROGRAMMING MODE.
Sep 10, 2011 | 2001 Chrysler Sebring
We own a 2000 Pontiac Grand AM, 3.4 liter, 2 door coupe with front wheel drive and recently replaced the transmission and now can't find our key set. Great start We hired a local Lock Smith who...
You can purchase new Remote Keyless Entry (RKE) transmitters from the dealer or you can order them online at the web sites listed below or several others. Your vehicle provides for programming the RKE transmitters without the use of a scan tool. Follow the instructions below.
2000 PONTIAC GRAND AM RKE TRANSMITTER PROGRAMMING
WITHOUT A SCAN TOOL
1. Close all vehicle doors. Remove key from ignition lock cylinder
NOTE: STEPS 2 AND 3 MUST BE COMPLETED WITHIN 25 SECONDS OF PRESSING THE DOOR UNLOCK SWITCH
2. Press and hold door UNLOCK switch. While holding UNLOCK switch, insert and remove the key in the ignition lock cylinder twice. Do not rotate the lock cylinder.
3. Insert the key a third time, leaving the key in the lock cylinder. Keep the lock cylinder in the LOCK position for the remainder of the procedure. Release the door UNLOCK switch. The chime will sound 3 times to signal that the programming/diagnostic mode is active.
4. Press and hold LOCK and UNLOCK at the same time on the RKE transmitter for approximately 4 seconds. The chime will sound 2 times signaling that the transmitter has been programmed.
5. Repeat step 4 for each transmitter being programmed. (You can program up to 4 transmitters.)
6. To exit program mode, turn the key to the RUN position then back to the LOCK position and remove the key. Your transmitters should now work to lock and unlock your doors.
2000 Pontiac Grand Am Transponder (direct links)
- autotransponder.com
-keylessremotes.com
-ikeyless.com
Jun 10, 2011 | Pontiac Grand Am Cars & Trucks
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
Keyless entry 2005 grand am i put new ignition on car, 2005 grand am it came 2005 grand am that i own that was wrecked my car that i want to put it on did have remotes when i bought it they were lost, igot...
To program the transmitters, perform the following procedure while seated in the vehicle driver's seat:
Close all the vehicle doors.
Remove the ignition key from the ignition lock cylinder.
Press and hold unlock on the door lock switch.
Important: To successfully enter the keyless entry programming/diagnostic mode, steps 4 through 6 must be completed within 25 seconds of pressing the door unlock switch.
While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
Release the door lock switch. The chime will sound three chimes to signal that transmitter programming/diagnostic mode is active.
Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for approximately 4 seconds. The chime will sound two times to signal that the transmitter has been programmed successfully.
To exit the transmitter programming/diagnostic mode perform either of the following:
• Turn the ignition switch to the RUN position.
• Remove the ignition key from the ignition switch
Oct 21, 2009 | 2005 Pontiac Grand Am
Where do I find the instructions for programing a buick century 1997 keyless remote?
METHOD 1 - NO TOOLS REQUIRED
  1. Sit in the vehicle driver's seat.
  2. Remove the ignition key from the ignition lock cylinder.
  3. Close all of the vehicle's doors.
  4. Press and HOLD the door "LOCK" switch to the "Unlock" position.
  5. Insert and remove the ignition key twice (without rotating the ignition lock cylinder).
  6. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must be in the "OFF" position.
  7. Release the door "LOCK" switch from the "Unlock" position (three fast chimes will be heard when the remote control door lock receiver enters the programming/diagnostic mode).
  8. Press and HOLD the transmitter "LOCK" and "UNLOCK" buttons simultaneously for at least 12 seconds . Two fast chimes will be heard confirming successful programming.
  9. Repeat step 8 for each additional transmitter to be programmed.
  10. Remove the ignition key from the ignition lock cylinder
Sep 26, 2009 | 1997 Buick Century
How do I reprogram the 2004 Pontiac Vibe key fob?
To begin programming, follow the procedure.
  1. Set the following conditions: • Ignition off and ignition key out of cylinder. • All doors closed except drivers door. • Drivers door is unlocked.
  2. Insert and remove the key from the ignition switch twice within 5 seconds.
  3. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
  4. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
  5. Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1to5 times to select desired mode. • 1 time for add mode • 2 times for rewrite mode • 3 times for confirmation mode • 5 times for prohibition mode
  6. Remove the ignition key from the key cylinder.
  7. After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode. • In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered. • In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times. • If the prohibition mode or confirmation mode is selected, registration procedure is completed. • If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode. • If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed. • If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
  8. Registering new recognition codes for the add mode or rewrite mode. • Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds. • Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
  9. Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter. • If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters. • If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
Jun 11, 2009 | 2003 Pontiac Vibe
Whirlpool WFC7500VW Washer Logo
153 people viewed this question
Dan Webster
Dan Webster
Sal De
