Question about Air Purifiers
Ionic comfort purifier wire replacement parts
Replace broken wire
SOURCE: I need a replacement light bulb for my Ionic breeze?
you can buy the lightbulb on line.. here is the link.. http://www.lightbulbmarket.com/product/738517
It is a Philips ULTRAVIOLET TUV15W/G 15 T8
Posted on Jan 09, 2009
SOURCE: Where can I have a Ionic Breeze Quadra Model S1637 repaired?
Try this link, pair for $10- http://breezerepair.com/parts.html
Posted on Feb 22, 2009
  • 6 Answers
SOURCE: my ionic breeze quadra GP silent air purifier has no power: stopped working!
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You want to take off the screws from both sides but only remove one side.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
localwonder
  • 6784 Answers
SOURCE: I have several ionic Breeze air purifiers that have problems
Unfortunately, there are no repair depots that are available for use since Sharp Image has claimed bankruptcy. these product are very unique in design and, the actual repair parts are no longer in stock. the suppliers went under when Sharp filed for bankruptcy.
You may be able to repair the wiring by ordering the identical gauge from you local electrician but, that's about it. most of the hardware is no longer available.
Posted on Jun 18, 2009
  • 94 Answers
SOURCE: I need to replace the bulb for ionic breeze air purifier S1830
G15T8 15W 15 Watt UV Germicidal Bulb IONIC BREEZE GP
this bulb is available on ebay for under $11.00. The release tab for the cover is at the bottom of the cover and it comes off pretty easy. Once the cover is off you turn the lamp 1/4 turn (two clicks) and slide it from it's fixture.
Posted on Jul 04, 2009
Ionic pro CA500
Yes, a new portion of wire can be put in place of the broken wire.
Sep 28, 2014 | Ionic Pro CA500 Air Purifier
One of the the two plates/contacts at the bottom of the filter is broken, what can I do to fix it?
Hi.
If you need parts or repair for new models contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read the below, in that case do not get the parts.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Note:On this particular problem: It is caused by arching, that was a factory defect. It is repaired replacing the plate. Since this is an old model, I suggest not repairing the unit.
Regards.
Ginko.
Sep 20, 2010 | Sharper Image Ionic Breeze 3.0 Air...
My ionic breeze quadra air purifier keeps turning on and off. I have cleaned the fins, what else can i do?
Hi.
The filter will probably need replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. Parts are also not distributed anymore.
Regards.
Ginko.
Sep 08, 2010 | Sharper Image Professional Plus Ionic...
One of the wires on my ionic breeze quadra broke. It is one of the wires that have the glass beads on them that you clean by turning the quadra up and down. Can it be replaced and how? Thanks.
You're probably screwed...
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Dec 02, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
I have an Ionic Breese Quarda that just stopped working all of a sudden. Is there someone who can walk me through some basic fixes? Company out of business I'm told.
The high-voltage grid wire(s) most likely broke -- unfortunately, there is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended. Even if the reapair is done, the unit will likely fail again, soon.
When my reapired units failed, I got units off E-Bay -- they didn't last very long either.
I'm now in the market for a more rugged ozone-generating air purifier.
Charlie
Sep 21, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
Broken Wire inside unit. Looking to have it repaired or purchase part.
You're probably screwed....
May 21, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
My wife wanted me to take it apart to clean it properly. we have the quadra which all of you know that it's impossible to clean. Well, after cleaning it, I noticed a fuse which is permanently in place...
You can replace the fuse by soldering a new one into place -- it's a standard fuse, just match the amp rating of old to new.
Chances are though, after you do this, it will blow again. So, there's a good chance the unit is kaput.
I have extensive experience with these units to the point of even replacing the high-voltage field wires (the two fine wires which run from top to bottom) with titanium wire. There is no real good way to keep these things running properly -- they're kinda like weed whackers -- inherently problematic.
Apr 20, 2009 | Sharper Image Professional Plus Ionic...
Air Purifiers Logo
308 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
