Question about Breville Coffee Makers & Espresso Machines
Water reservoir on breville still shows descale after cleaned twice with vinegar
  • 2039 Answers
SOURCE: CANNOT PRIME PUMP AFTER DESCALING - therefore CANNOT MAKE COFFEE
first vinegar is not strong enought proper descaler for expresso machine and in our water container the hole in the bottom put water in the tank with a hoseor turkey juicer our anything you got push water in hole you need to pressurize to forse the pummp to trim itself hope it help fixya pierre
Posted on Jul 28, 2008
  • 85 Answers
SOURCE: Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it, but most people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 09, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
  • 1416 Answers
SOURCE: I have water draining back into the reservoir. It
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Posted on Oct 15, 2010
heatman101
  • 43501 Answers
SOURCE: First time to descale coffee
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Posted on Feb 23, 2011
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
Water pump makes a lot of noise when pulling water from tank
You may need to descale the coffee machine... Use white vinegar and put into reservoir and run until reservoir is as empty as it will get. Fill with water and run to clear....I do this twice to make sure the vinegar odor is gone.
Oct 10, 2013 | Keurig Platinum B70 Coffee Maker
What is the BEST way to descale my Breville??
Try with vinegar same quantity like you use usual and after this clean up 3 times with fresh water. Just check .
May 08, 2011 | Breville BKC600XL Coffee Maker
Can I use vinegar to descale my Breville single cup coffeemaker?
White wine vinegar is a great descaler as it can dissolve the white deposits. For kettles, fill them up and leave them overnight. Don't boil it, though - the vinegar will froth up and go everywhere. Afterwards, rinse the kettle thoroughly, fill with water and boil before using it again. Malt vineger can also be used as the malt only adds flavor
May 05, 2011 | Breville BKC600XL Coffee Maker
The coffemaker won't brew and showed a descale message. What does that mean?
Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
1.Unplug the coffee machine and remove the cup.
2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
6.Unplug the machine and dump the water into the sink.
7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
Dec 10, 2010 | Keurig B70 Coffee Maker
How to clean the Keurig coffee maker.
fill the reservoir with distilled white vinegar and leave the brewer on for 4 hours (leaving the auto off option OFF). after the 4 hours, run the entire vinegar filled reservoir through the machine.
refill with water and repeat twice. your machine is now cleaned and descaled.
Apr 05, 2010 | Keurig Elite B40 Coffee Maker
Not enough water making it from holding tank to dispensing cup
your machine is "Short Cupping"
It needs to be descaled. Even though the descale light might not be on yet, the descale light only comes on when it is in SERIOUS need of a descaling. You should descale once every 3 months.
Fill reservoir with distilled white vinegar and leave the machine on for 4 hours (make sure to turn off the auto off option).
after 4 hours, run the vinegar through the machine until the reservoir is empty. Refill with water and repeat twice. you will notice a difference right when you start running vinegar through.
Apr 04, 2010 | Keurig Elite B40 Coffee Maker
What do I do when I have a descaling message on my breville?
run a full cycle with 2 cups vinegar. Let evrything cool. Repeat. reusing cold vinegar. Run 2 cycles with clear cold water. Discard water and vinegar. Ok now?
Feb 03, 2010 | Breville BKC600XL Coffee Maker
How do I descale my Breville BKC600XL
Why not just fill the tank with vinegar & run it through as per the manufacturers instructions
Nov 07, 2009 | Breville BKC600XL Coffee Maker
Descaling
Just use vinegar. Fill the reservoir with white vinegar, put a pot or big bowl under the spout, get ready as if you were going to brew and then press BOTH the one cup and two cup buttons together.
Run the vinegar through again when it's done, and then run clean (filtered, preferably) water through twice. You're done.
Feb 11, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee Makers & Espresso Machines Logo
22 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
