Question about Neff U1721 Double circotherm Electric Oven
"Element or thermostat - Neff U1721"
I have just read the pages for the above and tried to print them but only the matrix prints with no text. How do I print, please? Thanks
  • Neff Master
  • 3,463 Answers
In your browser bar type in-----windows print screen ,and follow the instructions for using the function, this should allow you to view the the page and download it to your printer.
Plz rate my solution.
Thanks.
Posted on Jan 18, 2009
My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Jun 10, 2010 | Neff U1721 Double circotherm Electric Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Oven not heating
Possibly a faulty element or maybe just an open circuit temperature switch, that's assuming the thermostat is ok.
You need a multimeter to start checking the continuity of the above.
An element will be something like 15 to 30 ohms, a temperature cutout switch located on the oven housing should have zero ohms across the contacts (when cold)
Hope this helps
Sep 30, 2009 | Neff U1721 Double circotherm Electric Oven
Element or thermostat - Neff U1721 cooker
Hi there.
It is possible that the element in your oven is faulty again without there being any external evidence that it is so..
To be certain whether it is faulty or not , you really need to test it with a meter,preferably an anologue one with a audible beep to test for continuity.
What you need to do is disconnect the element, and with the meter probes touch the terminals of the element, if it is o/k then the meter will beep, no beep ,element open circuit.
If your meter does not have a beeper, then set it the ohms range, and again test across the element terminals, if it is o/k then the pointer will deflect all the way across, no deflection, element
faulty.
It is doubtful that it will be a faulty thermostat,if the temp indicator light shows, that shows the supply is getting to the element.
If no light , then yes, it could be stat, to test if it is working, switch oven on, and with the element reconnected, test for voltage with the meter set on 240 volt range,no reading, stat faulty or no power between stat and element.
This should help you sort out what has happened.
Thanks.
Jan 13, 2009 | Neff U1721 Double circotherm Electric Oven
Unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Thanks.
Jan 11, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Oct 13, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
130 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
