Question about Emerson LC320EM8 32 in. LCD TV
Emerson LC320EM8A TV turns on but immediately turns off?
I was watching the TV for less than 5 minutes and it suddenly turned off. When I try to turn it on, it comes on but immediately goes back into standby mode, within 2 seconds. Occurs with both the remote and the set top button. The TV was manufactured 7/2007 and bought thereabouts. Have not had any issues prior to this one.
  • Jenni Estrada Dec 31, 2012
    After seeing a couple responses from 2009, I took the back off the TV to inspect. Looked okay, no obvious issues. Put it back together, along with a jostle or two, and now it works again. Am guessing the board is on its way out, but as the only one I can find anywhere is refurbished on Ebay, will wait until it crashes again to see about replacing.
daniel719
  • 240 Answers
SOURCE: Tv won't turn on...
the internal power supply needs to be repaired.
call us we do ups repairs.
thanks
hope this is of help to you.
719 687 6997
Posted on Jan 09, 2009
dsacco86
  • 1077 Answers
SOURCE: When i turn the tv on it goes to standby right away
If not under warranty, here's what you need to replace inside your TV. Power supply board BA71F0F01042.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Right now, only Discount-Merchant has one in stock. Here's the link:
Discount-Merchant.com - Projection LCD / DLP TV Lamps - Plasma ...
I know it would be cheaper to fix the TV, than replace it.
If you end up throwing the old board in the trash, I would like to keep it if possible. Here's my e-mail, dsacco86@hotmail.com
Posted on Apr 25, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Posted on Jun 18, 2009
SOURCE: I have an Emerson lc320em8a and can not use my
Try code 1817
Posted on Mar 15, 2010
SOURCE: my emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Posted on Dec 20, 2010
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
What is the digital code used by this remote to operate functions of an Emerson LCD Model LC320EM8A
Universal remote codes for Emerson Brand TVs are: 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Aug 20, 2012 | Emerson Used Original NF015UD Remote...
The TV set will not turn on. No previous problem.
Did you try changing the fuse in the plug?
May 01, 2010 | Emerson EWF2006 TV
Emerson 37" HD LC320EM8A flashes on and off
this is 9 times out of ten a bad relay or power supply unit there might be a bad capcitor inside that is causing this shutdown, I would rule out the powersupply before the relay at this point. Good luck when i doubt please bring it in for repair its still a good tv to invest in.
Sep 23, 2009 | Emerson EWL3706 37 in. LCD Television
Rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
Aug 22, 2008 | Televison & Video
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
Great sound no picture
When I turn my tv on there is one certain channel that goes black after watching less than 5 minutes. this might be due to electronic tuner or loose contact in that particular section. 100% problem will be solved thanks
Sep 09, 2007 | Sanyo DS24205 24" TV
Emerson LC320EM8 32 in. LCD TV Logo
79 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
